It is currently 29 Mar 2024
PostPosted: 25 May 2008
Band: Die Krupps
Label: Rough Trade
Year: 1995
Gerne: Industrrial
Country: GER
Format: APE
Line Up:
Jürgen Engler - Vocals, Keyboards, Metal percussion, Guitar
Lee Altus - Guitars
Ralf Dörper - Samples
Chris Lietz - Drum programming
Rüdiger Esch - Bass guitar
1. The Last Flood
2. Isolation
3. Odyssey Of The Mind
4. Eggshell
5. Scent
6. The Final Option
7. LCD
8. Jeckyll Or Hyde
9. Metalmorphosis
10. Alive
11. Odyssey of the Mind *
12. The Final Option (S.P.Q.R-mix) *
13. LCD *
EAC extraction logfile from 23. April 2007, 16:24 for CD
Die Krupps / III - Odyssey of the mind
Used drive : _NEC DVD_RW ND-4571A Adapter: 4 ID: 0
Read offset correction : 48
Used output format : C:\Program Files\Monkey's Audio\MAC.exe (Monkey's Audio Lossless Encoder)
Extra High Lossless Compression
Other options :
Filename C:\_____\Die Krupps - III - Odyssey of the mind.wav
Peak level 97.2 %
CRC EB4988E4
No errors occured
Part 1
Part 2
Part 3
Part 4
Плин, альбом у меня есть на диске, но скачаю. Потому как пусть будет :nunu:
Тхенькс
