METAL HAMMER ROAD SHOW 1986. U.S. SPEED METAL ATTACK
Featuring AGENT STEEL, OVER KILL & ANTHRAX.
Filmed on 12-5-86 in Bochum Germany.
A killer professionally shot concert from speed metal's glory days.
ещё вариант обложки был такой:
AGENT STEEL:
Never Surrender
Children Of The Sun
Unstoppable Force
144,000 Gone
Bleed For The Gods
OVER KILL:
Rotten To The Core
Second Son
Hammerhead
Over Kill
ANTHRAX:
A.I.R.
Anthrax
Metal Thrashing Mad
Panic
Gung Ho
Total time: 01:03:47
VHSrip
Качество изображения удовлетворительное
media info:
METAL HAMMER ROADSHOW - AGENT STEEL, OVERKILL & ANTHRAX (1986).mpg
Format : MPEG-PS
File size : 636 MiB
Duration : 1h 3mn
Overall bit rate : 1 394 Kbps
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 1h 3mn
Bit rate : 1 150 Kbps
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.454
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 521 MiB (82%)
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 1h 3mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 102 MiB (16%)
https://yadi.sk/i/-m3zuJu3bfZff
