It is currently 10 Mar 2026
PostPosted: 26 Mar 2014
Image Image Image
Image Image Image
Crumbsuckers - CBGB'S NYC - 22.1986.avi
Narod l M-Cloud
MediaInfo
Format : AVI
Format/Info : Audio Video Interleave
File size : 992 MiB
Duration : 31mn 17s
Overall bit rate : 4 434 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 31mn 17s
Bit rate : 4 198 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.405
Stream size : 939 MiB (95%)
Title : Video
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Duration : 31mn 16s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 50.1 MiB (5%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 750 ms
Title : Audio
