It is currently 07 Mar 2026
PostPosted: 21 Mar 2014
Lоcаtion: Киев
Raven&Girlschool - at King Tut"s ,Glasgow, 27 November,2013.
Нормальное для самопальной съёмки видео, файлы расжаты в DVD5 Large формат.
Raven-00:52:03 min.
Girlschool - 00:42:33 min.
Raven:
http://yadi.sk/d/pu0_PIF0KxZtk
Girlschool:
http://yadi.sk/d/WaK_maugKxVkU
Raven .vob info:
Format : MPEG-PS
File size : 2.31 GiB
Duration : 52mn 3s
Overall bit rate mode : Variable
Overall bit rate : 6 364 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Default
Format settings, GOP : N=15
Duration : 52mn 3s
Bit rate mode : Variable
Bit rate : 5 789 Kbps
Maximum bit rate : 9 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.558
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 2.11 GiB (91%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 52mn 2s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 167 MiB (7%)
Girlschool .vob info:
Format : MPEG-PS
File size : 1.76 GiB
Duration : 42mn 33s
Overall bit rate : 5 910 Kbps
Video
Format : MPEG Video
Duration : 42mn 33s
Bit rate : 5 344 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.515
Stream size : 1.59 GiB (90%)
Audio
Format : AC-3
Duration : 42mn 33s
Bit rate : 448 Kbps
Bit depth : 16 bits
Stream size : 136 MiB (8%)
P.S.
Raven- приедут в Европу летом 2014,на фестиваль в Бельгии,там же будут и Chariot.
PostPosted: 22 Mar 2014
:shok: Фигасе размерчеги... :thanx:
Girlschool
mirror: Narod l M-Cloud
Raven
mirror: Narod - pt1 l Narod - pt2 l M-Cloud - pt1 l M-Cloud - pt2
PostPosted: 23 Mar 2014
Lоcаtion: Киев
Есть и (2Гб.) Raven в Далласе,2013(в забегаловке *Котельная* на ул. Вязов).Там изображение чуть похуже-но снимали вплотную к группе- никаких рамп, заграждений и т.д...Валят классические вещи середины 80-х, как всегда.
Ааа, етить, я чего-то подумал, что здесь... по клипу :shok: :oops:
Сань, а Даллас тоже редкость кагбе? :umnik:
Lоcаtion: Киев
Не редкость, дело в формате,эти которые здесь- подготовлены на болванку,на любом DVD железном плэере гонять.
Понял :thanx: Тогда явно не нужно их сюда... :vic:
Lоcаtion: Киев
в этом формате-только здесь.
Понял-2 :lloo:
