It is currently 15 Jul 2026
PostPosted: 15 Mar 2014
Lоcаtion: Киев
Rock Goddess - Live at the Marquee Club
2,3 February 1984, for the British TV show Live from London
Известная серия записей Live from London в клубе Marquee,изображение нормальное.
Guitar/Vocals- Jody Turner
Bass/Vocals-Dee O"Malley
Drums/Vocals-Julie Turner
Satisfied Then Crucified
Hold Me Down
Heavy Metal Rock N' Roll
Hell Hath No Fury
My Angel
Bang Bang
Back to You
The Visitors Are Here
Gotta Let Your Hair Down
Nights In White Satin
God Be With You
I Didn't Know I Loved You(Till I Saw You Rock N' Roll)
You've Got The Fire
One Hot Night
Total time:0:59:05
TRILION PICTURES Ltd (c) 1984
AVI:
http://yadi.sk/d/mCtvdWvjKbAdZ
AVI media info:
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 1.05 GiB
Duration : 59mn 5s
Overall bit rate : 2 532 Kbps
Writing application : MEncoder SVN-r30881(20100311-gcc4.3.3)
Writing library : MPlayer
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 59mn 5s
Bit rate : 2 324 Kbps
Width : 760 pixels
Height : 520 pixels
Display aspect ratio : 3:2
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.235
Stream size : 982 MiB (92%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 59mn 5s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 40ms
Stream size : 81.2 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 522 ms
DVD5:
http://yadi.sk/d/hsxe5OJhKeuTV
DVD5 info:
Качество : DVD5
Формат: DVD video
Видео кодек: MPEG2
Аудио кодек: AC3
Видео: PAL 4:3 (704x576), ~ 4716.10 kbps avg, 25 fps
Аудио: Dolby AC3, 256 kbps, 48 kHz, 2 ch
другая версия, в ДВД5, качество лучшее,диск не с *Гитарс101*,но это-тоже самопал,официального быть не может.В архиве,1.91Гб.
PostPosted: 16 Mar 2014
:thanx: :thanx: :thanx:
