It is currently 05 Mar 2026
PostPosted: 02 Mar 2014
Lоcаtion: Киев
Rockstage at Nottingham Theatre Royal
Show recorded - 20\08\1980
Broadcast - 4 april 1981
Duration : 35mn 33s
качество - нормальное,Eddie Clarke даже поёт.
в двух вариантах,исходником для расжатия в .avi служила версия .mpeg
Overkill
Too late too late
Shoot you in the back
Step down (E.Clarke- voc.)
Jailbait
Leavin here
Metropolis
Train kept a rollin
Bomber
Motorhead
Drums - Phil Taylor
Lead Guitar&Vocals - Eddie Clarke
Vocals&Bass-Lemmy Kilmister
(C)ATV Network Limited MCMLXXXI
медиа инфо.mpeg версии:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 169 MiB
Duration : 35mn 33s
Overall bit rate mode : Variable
Overall bit rate : 663 Kbps
Encoded date : UTC 2013-12-19 06:20:38
Tagged date : UTC 2013-12-19 06:20:38
gsst : 0
gstd : 2134006
gssd : B4A7DAD42HH1393580552382698
gshh : r5---sn-4g57kn6k.googlevideo.com
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L2.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=60
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 35mn 33s
Bit rate : 565 Kbps
Maximum bit rate : 1 234 Kbps
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.131
Stream size : 144 MiB (85%)
Tagged date : UTC 2013-12-19 06:21:48
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 35mn 33s
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Maximum bit rate : 100 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 24.4 MiB (14%)
Title : IsoMedia File Produced by
версия .mpeg :
http://yadi.sk/d/Jpklp9JwJnPot
версия АВИ:
http://yadi.sk/d/Ylrtl_RbK4YQo
медиа инфо .avi версии:
Format : AVI
Format/Info : Audio Video Interleave
File size : 322 MiB
Duration : 35mn 33s
Overall bit rate : 1 268 Kbps
Writing application : MEncoder SVN-r30881(20100311-gcc4.3.3)
Writing library : MPlayer
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 35mn 33s
Bit rate : 1 127 Kbps
Width : 480 pixels
Height : 360 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.261
Stream size : 287 MiB (89%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 35mn 33s
Bit rate mode : Constant
Bit rate : 128 Kbps
Delay relative to video : 40ms
Stream size : 32.6 MiB (10%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 522 ms
Writing library : LAME3.98
