It is currently 25 Apr 2024
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: 27 Aug 2013
Это вроде не оно...
Ага. Оно. с 02:23 начало :dance:
Metal Head Video Magazine - Volume I
mirror:
1 - F-Bit l eDisk l Narod
2 - F-Bit l eDisk l Narod
3 - F-Bit l eDisk l Narod
4 - F-Bit l eDisk l Narod
MediaInfo
Format : MPEG-PS
File size : 1 016 MiB
Duration : 7s 529ms
Overall bit rate : 1 132 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Duration : 7s 529ms
Bit rate : 1 109 Mbps
Maximum bit rate : 8 040 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 106.985
Stream size : 994 MiB (98%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 7s 313ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -80ms
Stream size : 229 KiB (0%)
Menu
