It is currently 07 Jul 2026
PostPosted: 09 Aug 2013
Lоcаtion: Киев
V/A – In Conspiracy With Satan - A Tribute To Bathory 2001
discogs
Label: Фоно – FO95CD
Format: CD, Compilation
Country: Russia
Released: 2001
Genre: Rock
Style: Black Metal, Viking Metal
Tracklist
1 Marduk – In Conspiracy With Satan 2:16
2 Ophthalamia – Sacrifice 2:53
3 Gehennah – Reaper 2:59
4 Dark Funeral – Equimanthorn 3:20
5 Emperor (2) – A Fine Day To Die 8:27
6 Lord Belial – Massacre 2:33
7 Abyss, The (2) – Armageddon 2:21
8 Marduk – Woman Of Dark Desires 4:28
9 Nifelheim – Die In Fire 3:26
10 Necrophobic – Enter The Eternal Fire 4:50
11 Dark Funeral – Call From The Grave 4:34
12 Sacramentum – 13 Candles 6:33
13 Unanimated – Raise The Dead 3:06
14 Satyricon – Born For Burning 5:18
15 War (4) – War 2:07
Companies etc
Licensed From – Hammerheart Records
Recorded At – The Abyss
Recorded At – Sunlight Studios
Recorded At – Grieghallen Studio
Recorded At – Los Angered Recording
Recorded At – Ancient Spectre Ruins
Notes
Tracks 1,8 recorded at The Abyss 95 & 97.
Tracks 2,4,11 recorded at The Abyss 96.
Track 3 recorded at Sunlight Studio 97.
Track 5 recorded at Grieghallen, October 1996.
Track 6 recorded in Studio 97.
Track 7 recorded at The Abyss 95.
Track 9 recorded in Studio RH 97.
Track 10 recorded in Hell 95.
Track 12 recorded at Los Angered 97.
Track 13 recorded at Sunlight Studio 95.
Track 14 recorded at the Ancient Spectre Ruins, Autumn 95.
Track 15 recorded at The Abyss 97.
Barcode and Other Identifiers
Matrix / Runout: FO 95 CD
Mastering SID Code: IFPI L431
Mould SID Code: IFPI LC77
Отчёт EAC об извлечении, выполненном 9. августа 2013, 14:23
V-A / in conspiracy with satan/FONO FO95CD/2001
Дисковод: ASUS DRW-1608P2S Adapter: 0 ID: 0
Режим чтения : Достоверность
Отключение кэша аудио : Да
Коррекция смещения при чтении : 48
Интерфейс : Установленный внешний ASPI-интерфейс
TOC извлечённого CD
1 | 0:00.00 | 2:16.02 | 0 | 10201
2 | 2:16.02 | 2:53.34 | 10202 | 23210
3 | 5:09.36 | 2:59.14 | 23211 | 36649
4 | 8:08.50 | 3:20.34 | 36650 | 51683
5 | 11:29.09 | 8:27.17 | 51684 | 89725
6 | 19:56.26 | 2:33.54 | 89726 | 101254
7 | 22:30.05 | 2:21.51 | 101255 | 111880
8 | 24:51.56 | 4:28.48 | 111881 | 132028
9 | 29:20.29 | 3:26.47 | 132029 | 147525
10 | 32:47.01 | 4:50.51 | 147526 | 169326
11 | 37:37.52 | 4:34.36 | 169327 | 189912
12 | 42:12.13 | 6:33.06 | 189913 | 219393
13 | 48:45.19 | 3:06.25 | 219394 | 233368
14 | 51:51.44 | 5:18.13 | 233369 | 257231
15 | 57:09.57 | 2:07.61 | 257232 | 266817
Выбранный диапазон
Имя файла C:\Documents and Settings\Admin\Рабочий стол\ЕАС-выходная\V-A in conspiracy with satan,FONO FO95CD,2001.wav
Пиковый уровень 96.9 %
Скорость извлечения 7.2 X
Качество диапазона 100.0 %
CRC теста 591E1AF7
CRC копии 591E1AF7
Копирование... OK
Ошибок не произошло
AccurateRip: сводка
Трек 1 : извлечено точно (доверие 2) [3E46D8B9] (AR v1)
Трек 2 : извлечено точно (доверие 2) [1D2D3C5D] (AR v1)
Трек 3 : извлечено точно (доверие 2) [562ADF74] (AR v1)
Трек 4 : извлечено точно (доверие 2) [70822334] (AR v1)
Трек 5 : извлечено точно (доверие 2) [90D66982] (AR v1)
Трек 6 : извлечено точно (доверие 2) [87A7ED98] (AR v1)
Трек 7 : извлечено точно (доверие 2) [1F31EAD1] (AR v1)
Трек 8 : извлечено точно (доверие 2) [81C1966E] (AR v1)
Трек 9 : извлечено точно (доверие 2) [720B1921] (AR v1)
Трек 10 : извлечено точно (доверие 2) [D2F75D9F] (AR v1)
Трек 11 : извлечено точно (доверие 2) [15002E06] (AR v1)
Трек 12 : извлечено точно (доверие 2) [BB0C8FC3] (AR v1)
Трек 13 : извлечено точно (доверие 2) [824F6AEC] (AR v1)
Трек 14 : извлечено точно (доверие 2) [99B3C730] (AR v1)
Трек 15 : извлечено точно (доверие 2) [683A9898] (AR v1)
Все треки извлечены точно
Конец отчёта
http://f-bit.ru/199682
В архиве буклет полностью...
.... :fingal: ....
PostPosted: 10 Aug 2013
Алекс, угадай с пяти попыток, что не так у тебя в оформлении поста? :dance:
PostPosted: 11 Aug 2013
Lоcаtion: Киев
Долго гадать, лучше напишите.
Алекс.
Здравствуйте.
Меня попросили только что быть кратким... коротким... эээ... :vic:
Хм... буду краток :umnik:
Лог прячется под спойлер. Это вот такая пофиговинка
вот тута лог вставляем
Второе, тема отправляется в раздел для неформата. Все же black metal не наш раздел музыки.
С надеждой на понимание и еще как минимум три месяца лета :thanx:
Lоcаtion: Киев
Не формат-так *неформат*,переиграли вещи второй половины 80-х годов.
:dance: О, теперь почти всё идеально. Пардон за "нависания", но так ведь красившее и культурнее выглядит всё :thanx:
Lоcаtion: Киев
Не, Саныч, правильно нависали-если что не так поправьте. Наверное надо для *пущести* добавить изображение какой нибудь программы ,которая снимает частотку,спектр и т.д... но это означает устанавливать очередную программу для снятия такого изображения, правильно?В этот вопрос с * правильными* рипами с помощью EAC и других дополнительных программ пока не лез так глубоко, вот и спрашиваю.
PostPosted: 12 Aug 2013
Ну вот норм-норм. Про спрашивание :thanx:
Итак, чего я лично хотел бы здесь видеть. Частотно-спектральный анализ (скрины), сделанный в программке Adobe Audition, SoNy Sound Forge или же еще каких-то подобных.
Ну и главная оказаия - рипы принято делать одним куском, а не протрэкового. И зазоры... С зазароми я сам ничего посоветовать не могу, ибо не рипаю диски.
В общем, все же лучше было бы один раз и навсегда настроить ЕАК по мануалу от Олежки и не переделывать рипы несколько раз непонятно чем.
Еще могу сказать, что вряд ли данный рип много народу качать будет. Но тоже уже такое. Издержки производства, мелочишко.
Lоcаtion: Киев
Вторично оцифровывать его нет смысла. Насчет одним файлом- эт понял. Насчет этих программ по снятию изображения- посмотрю.С *рутрэкерной*историей знаком, как все,просто не обращал внимания на некоторые детали т.н. правильного рипа.
