It is currently 19 Jul 2026
PostPosted: 03 Apr 2018
Dammaj - "Mutiny" - 1986 ( Reissue 2012 Skol Records SR 005 )
1. Smuggler 04:30
2. Devils & Angels 04:31
3. March of the Gladiators 05:21
4. Without You 03:12
5. Mutiny 05:53
6. Leather Master 04:52
7. Clashes of Steel 05:28
8. To the Bitter End 01:36
9. Another Lonely Night 05:48
10. March of the Gladiators 05:22
11. Leather Master 05:02
12. Metal Rules 04:22
13. Devils & Angels 04:29
Тотаl Time: 01:00:26
Ой! :crazy:
Толя, не обязательно в новой теме. Но так ещё краше будет :kro:
Страна не указана. Группы страна.
PostPosted: 05 Apr 2018
Lоcаtion: Serbia
I have it. I'll post it tomorrow
Заранее ура :kro:
PostPosted: 07 Apr 2018
Lоcаtion: Serbia
Flac with scans
pics
EAC extraction logfile from 7. April 2018, 19:16
Dammaj / Mutiny
Used drive : HL-DT-STBD-RE BH16NS40 Adapter: 1 ID: 0
Read offset correction : 6
Selected bitrate : 896 kBit/s
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -6 -V %source% -
1 | 0:00.00 | 4:30.00 | 0 | 20249
2 | 4:30.00 | 4:25.56 | 20250 | 40180
3 | 8:55.56 | 5:19.00 | 40181 | 64105
4 | 14:14.56 | 3:07.02 | 64106 | 78132
5 | 17:21.58 | 5:57.24 | 78133 | 104931
6 | 23:19.07 | 4:51.68 | 104932 | 126824
7 | 28:11.00 | 5:24.66 | 126825 | 151190
8 | 33:35.66 | 1:35.50 | 151191 | 158365
9 | 35:11.41 | 5:47.60 | 158366 | 184450
10 | 40:59.26 | 5:21.48 | 184451 | 208573
11 | 46:20.74 | 5:02.30 | 208574 | 231253
12 | 51:23.29 | 4:21.67 | 231254 | 250895
13 | 55:45.21 | 4:29.17 | 250896 | 271087
Filename E:\Dammaj - Mutiny\Dammaj - Mutiny.wav
Extraction speed 6.1 X
Range quality 99.9 %
Test CRC E8DFC9E3
Copy CRC E8DFC9E3
Track 1 accurately ripped (confidence 1) [B34E5BB8] (AR v2)
Track 2 cannot be verified as accurate (confidence 1) [7A2BC5A9], AccurateRip returned [F7E9A4BF] (AR v2)
Track 3 accurately ripped (confidence 1) [51E7E1AA] (AR v2)
Track 4 accurately ripped (confidence 1) [217546C6] (AR v2)
Track 5 accurately ripped (confidence 1) [B032B82F] (AR v2)
Track 6 accurately ripped (confidence 1) [EA478B1C] (AR v2)
Track 7 accurately ripped (confidence 1) [E7F876FC] (AR v2)
Track 8 accurately ripped (confidence 1) [70BF2A61] (AR v2)
Track 9 accurately ripped (confidence 1) [00D0065F] (AR v2)
Track 10 accurately ripped (confidence 1) [D273DB83] (AR v2)
Track 11 accurately ripped (confidence 1) [52C6250B] (AR v2)
Track 12 accurately ripped (confidence 1) [0DA6A484] (AR v2)
Track 13 accurately ripped (confidence 1) [2CCF68C7] (AR v2)
12 track(s) accurately ripped
1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
[CTDB TOCID: VC.QEq_sGvJtuXXDV1Yr4Ph_R3g-] found
Submit result: VC.QEq_sGvJtuXXDV1Yr4Ph_R3g- has been confirmed
Track | CTDB Status
1 | (2/2) Accurately ripped
2 | (1/2) Accurately ripped
3 | (2/2) Accurately ripped
4 | (2/2) Accurately ripped
5 | (2/2) Accurately ripped
6 | (2/2) Accurately ripped
7 | (2/2) Accurately ripped
8 | (2/2) Accurately ripped
9 | (2/2) Accurately ripped
10 | (2/2) Accurately ripped
11 | (2/2) Accurately ripped
12 | (2/2) Accurately ripped
13 | (2/2) Accurately ripped
==== Log checksum 65B546F263B319AD3AFA7D84A90A3B5B68E978A7E70C21E646D58F3C51C2F59B ====
REM GENRE "Heavy Metal"
REM DATE 2012
REM DISCID A20E1E0D
PERFORMER "Dammaj"
TITLE "Mutiny"
REM COMPOSER ""
FILE "Dammaj - Mutiny.flac" WAVE
TITLE "Smuggler"
PERFORMER "Dammaj"
REM COMPOSER ""
TITLE "Devils & Angels"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 04:30:00
TITLE "March Of The Gladiators"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 08:55:56
TITLE "Without You"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 14:14:56
TITLE "Mutiny"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 17:21:58
TITLE "Leather Master"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 23:19:07
TITLE "Clashes Of Steel"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 28:11:00
TITLE "To The Bitter End"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 33:35:66
TITLE "Another Lonely Night"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 35:11:41
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 40:59:26
TRACK 11 AUDIO
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 46:20:74
TRACK 12 AUDIO
TITLE "Metal Rules"
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 51:23:29
TRACK 13 AUDIO
PERFORMER "Dammaj"
REM COMPOSER ""
INDEX 01 55:45:21
Хвала, брате! :thanx: :true:
mirror: Giga l Drop l Narod l M-Cloud
PostPosted: 08 Apr 2018
Спасибо!
PostPosted: 11 Apr 2018
glory11 wrote:
Flac with scans
крутяк, спасибо. Запись существенно слушабельней: нравятся и песни, и мощные рифы, и прекрасный вокал (есть в вибрато что-то сходное с молодым Де Фейсом, когда тот еще пел своим голосом)...есть в звуке и гармониях что-то от первенцев Savatage, ну и да - звук так же сыроват слегка. Короче как по мне, достойно ранней классики us power, хотя в 86 могли бы вырулить звучок и пожестче - Sava так писались парой-тройкой лет ранее (претензия именно к звукачам, а не музыкантам)
PostPosted: 21 May 2018
Пардон, конечно, но саунд на уровне 3 из 5 баллов :pardon:
И мало того, что само качество записи не очень (хотя низы мягкие и басовитые одновременно мне ну очень понравились), так ещё и рип с ленты (а я в этом более чем убеждён), весьма посредственного качества.
Виталия на это издание нет, хорошего состояния винила и пару суток работы над снятием звука и чисткой.
По-моему, Толя, только и ждёт, когда Виталий появится в этой теме, потому до сих пор затаился.
То что рип именно с ленты, а не с винила чётко слышно как раз на самой хитовой композиции.
Здесь (на Ютубе) она звучит ровно, тиховато и в общем, единородно, хоть и плоско.
А вот на данном ремастере левый канал полностью появился... только перед самым припевом :tro:
Сравнивайте, измеряйте, слушайте, прочее...
Мне альбом понравился выборочно - одной (вот этой) песней и местами выборочно припевами или какими-то солячками или вокальными партиями.
В финале полного альбома есть пару инструменталок "под классику". Так вот, на "To The Bitter End" очень заметен эффект "растянутой ленты" :garmo:
Следующий трэк вообще начинается со смазанных тарелок, тьхзу.. как на mp3@128 :yyy:
6+/10
зы. Да, о чём музыка и на кого подобна, Коля выше напечатал.
Пардон-2
Оказалось, что на этом CD-ремастере.. 2 таких композиции (одна и с интро, вторая без и продолжительнее), и указанный мной дефект находится на второй. То есть, бонусной версии, которая то точно с ленты "снята" :pardon:
PostPosted: 22 May 2018
Андрiй, ты сам запутался и людей путаешь...
Это конечно было бы просто здорово! Но если и будет, то боюсь ооочень не скоро...
PostPosted: 23 May 2018
Да, поначалу запутался. Затем распутался сразу же.
Тебе что-то не ясно из моих живых размышлений?
Спасибо за отзыв по данному рипу :thanx:
Запрос открыт пока, Толя?
Мне не ясно почему я вчера рисковал своей жизнью и лез на антресоль.
Одинаковые артефакты на обоих релизах. Качество... 50/50.
Да, пусть пока побудет.
Явно ты там что-то заныкал, чтобы 26 мая выпить :bodun:
О, начинается.. на каким обоих? :shok: И какие именно артефакты та самолично заметил?
Ок =) Мне уже самому интересно послушать все имеющиеся рипы :crazy:
Нет. Явно из-за того, что "кто-то" чего-то, где-то перепутал. :crazy:
На этом и на другом, который тоже тут есть.
Винил бы заслушать.
