It is currently 12 Mar 2026
PostPosted: 06 Apr 2010
UNDERGROUND OUTLAWS - 1993 - S/T
* 1. I Miss The Old You (3:04)
* 2. Put A Little Distance (3:49)
* 3. Tonky Honkin' (3:24)
* 4. Daddy's Little Girl (3:43)
* 5. It'll Be All Right (4:44)
* 6. Leave The Past Behind (3:44)
* 7. Backseat Driver (4:11)
* 8. Silver Lining (3:37)
* 9. (you Are) My Best Friend (3:36)
* 10. Restless (3:58)
* 11. I Drink To Forget (2:08)
The line-up of Cory and Kevin Churko, Mike Norman and Shane Hendrickson released two CDs in 1993, one as The Explorers (We Always Want) and one as these guys: Underground Outlaws. Where the Explorers fused big stadium choruses a la Def Leppard and Bryan Adams, the Underground Outlaws were an honest mix of "Wanted Dead or Alive" Bon Jovi and "Every Rose Has Its Thorn" Poison with some more traditional southern elements. The song "Daddy's Little Girl" is a perfect example of this. Had Jon Bon Jovi recorded this sweet campfire rocker, it would have probably been a worldwide smash hit. Of course, these Outlaws remained Underground because the 1993 climate was inhospitable to hair rock, no matter how earnest. Luckily, the talented Churkos would get their moment of glory, teaming up years later with Shania Twain for her Up! CD. This CD is so rare, it's the first time I've been lucky enough to find it. Don't miss out on these elusive Outlaws!
ebay
PostPosted: 15 Jun 2011
Зарегился вот...
Lоcаtion: asturias
:esel:
Зарегился вот...
Lоcаtion: asturias
meanacoalla, prefix [reqs] means the request. That is, we ourselves are looking for this album :pardon:
похоже диск ушёл :oops:
PostPosted: 09 Mar 2012
Lоcаtion: USA
1993 release from UNDERGROUND OUTLAWS - 11 tracks. I was curious, as the back insert of the CD has 4 guys who really look like rockers, but song titles that look country - in this case the picture and words combine to tell the truth. Spun through the tracks, and what you get is a country rock disc, with an influence of melodic rock/AOR - a very cool disc!!!
ebay
:dash: forgot to place my bid
PostPosted: 21 Mar 2012
http://www.musicstack.com/item/341354118
PostPosted: 03 Mar 2015
Underground Outlaws - Underground Outlaws (1993) [320 kbt/s]
http://tempfile.ru/file/3116094
Какой-то кантри-рок :crazy:
PostPosted: 04 Mar 2015
:thanx: :thanx: :thanx:
Lоcаtion: Russia (Bryansk)
http://www.israbox.net/1146556572-underground-outlaws-underground-outlaws-1993.html :pardon:
EAC extraction logfile from 12. October 2012, 15:12
Underground Outlaws / Underground Outlaws
Used drive : HL-DT-STDVD-RAM GSA-H55N Adapter: 0 ID: 0
Read offset correction : 102
Gap handling : Appended to previous track
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\FLAC\flac.exe
Additional command line options : -V -8 -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" %source%
1 | 0:00.32 | 3:04.73 | 32 | 13904
2 | 3:05.30 | 3:49.45 | 13905 | 31124
3 | 6:55.00 | 3:24.47 | 31125 | 46471
4 | 10:19.47 | 3:43.05 | 46472 | 63201
5 | 14:02.52 | 4:44.50 | 63202 | 84551
6 | 18:47.27 | 3:44.05 | 84552 | 101356
7 | 22:31.32 | 4:11.03 | 101357 | 120184
8 | 26:42.35 | 3:37.32 | 120185 | 136491
9 | 30:19.67 | 3:36.40 | 136492 | 152731
10 | 33:56.32 | 3:58.55 | 152732 | 170636
11 | 37:55.12 | 2:09.30 | 170637 | 180341
Track 1
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\01 - I Miss the Old You.wav
Pre-gap length 0:00:02.42
Peak level 93.7 %
Extraction speed 0.9 X
Track quality 99.8 %
Test CRC FF67E313
Copy CRC FF67E313
Track not present in AccurateRip database
Track 2
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\02 - Put a Little Distance.wav
Pre-gap length 0:00:00.33
Peak level 93.7 %
Extraction speed 1.6 X
Track quality 100.0 %
Test CRC 379C7462
Copy CRC 379C7462
Track 3
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\03 - Tonky honkin'.wav
Pre-gap length 0:00:01.97
Peak level 93.7 %
Extraction speed 1.8 X
Test CRC C726CB4B
Copy CRC C726CB4B
Track 4
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\04 - Daddy's Little Girl.wav
Pre-gap length 0:00:01.56
Peak level 93.7 %
Extraction speed 1.7 X
Track quality 99.9 %
Test CRC F5C08880
Copy CRC F5C08880
Track 5
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\05 - It'll Be All Right.wav
Pre-gap length 0:00:00.76
Peak level 93.7 %
Extraction speed 2.1 X
Test CRC 0122F7E8
Copy CRC 0122F7E8
Track 6
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\06 - Leave the Past Behind.wav
Pre-gap length 0:00:01.33
Peak level 93.7 %
Extraction speed 1.9 X
Test CRC 66FF2398
Copy CRC 66FF2398
Track 7
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\07 - Backseat Driver.wav
Peak level 93.7 %
Extraction speed 2.3 X
Test CRC 204969EE
Copy CRC 204969EE
Track 8
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\08 - Silver Lining.wav
Pre-gap length 0:00:04.46
Peak level 93.7 %
Test CRC 79C8D1A5
Copy CRC 79C8D1A5
Track 9
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\09 - (You are) My Best Friend.wav
Pre-gap length 0:00:00.96
Peak level 93.7 %
Extraction speed 2.4 X
Test CRC 98A949A0
Copy CRC 98A949A0
Track 10
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\10 - Restless.wav
Pre-gap length 0:00:01.73
Peak level 93.7 %
Test CRC FB0DB05E
Copy CRC FB0DB05E
Track 11
Filename C:\Users\Evelyn_Brian\Documents\Uploaded Flac Rips\Underground Outlaws - Underground Outlaws\11 - I Drink to Forget.wav
Pre-gap length 0:00:03.02
Peak level 93.7 %
Extraction speed 2.8 X
Test CRC 260F5C0D
Copy CRC 260F5C0D
==== Log checksum F3BB0D553F72BF84E909628AAA4AB3C0D937AC15C29D2012CD2D94CDC8C8FF43 ====
REM GENRE Country
REM DATE 1993
REM DISCID 8609640B
CATALOG 0000000000000
PERFORMER "Underground Outlaws"
TITLE "Underground Outlaws"
FILE "01 - I Miss the Old You.wav" WAVE
TITLE "I Miss the Old You"
PREGAP 00:00:32
TITLE "Put a Little Distance"
INDEX 00 03:04:48
FILE "02 - Put a Little Distance.wav" WAVE
TITLE "Tonky honkin'"
INDEX 00 03:47:47
FILE "03 - Tonky honkin'.wav" WAVE
TITLE "Daddy's Little Girl"
INDEX 00 03:23:05
FILE "04 - Daddy's Little Girl.wav" WAVE
TITLE "It'll Be All Right"
INDEX 00 03:42:23
FILE "05 - It'll Be All Right.wav" WAVE
TITLE "Leave the Past Behind"
INDEX 00 04:43:25
FILE "06 - Leave the Past Behind.wav" WAVE
TITLE "Backseat Driver"
INDEX 00 03:43:23
FILE "07 - Backseat Driver.wav" WAVE
TITLE "Silver Lining"
INDEX 00 04:06:43
FILE "08 - Silver Lining.wav" WAVE
TITLE "(You are) My Best Friend"
INDEX 00 03:36:35
FILE "09 - (You are) My Best Friend.wav" WAVE
TITLE "Restless"
INDEX 00 03:34:60
FILE "10 - Restless.wav" WAVE
TRACK 11 AUDIO
TITLE "I Drink to Forget"
INDEX 00 03:55:53
FILE "11 - I Drink to Forget.wav" WAVE
Спасибо! :thanx:
PostPosted: 05 Mar 2015
Мдя... музычка хоть и хороша, но неформатная. Переносится в раздел по АОРу.
Здесь, как уже было отмечено - поп-рок с сильный креном в кантри. Но, иногда попадаются и красивые поп-рок баллады, две из которых как раз, пусть и с большой натяжкой, но можно отнести с такому стилю, как AOR.
Самую яркую песню и нетипичную для всего альбома, чуть ниже можно и оценить:
Вот вам показательный пример, как легко ввести людей в заблуждение, указав неверно стилистику исполнителя, тыкнув им под нос такой вот трэк :pardon:
Правда, весьма похоже на ранее сольное *ковбойское" творчество Джона Bon Jovi? :lloo:
5/10
