It is currently 16 Apr 2024
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: 08 Jul 2009
Lоcаtion: Таллин, Эстония.
Sacrifice (Canada) - Torment In Fire 1985 (1991 Fringe FPD3020)
Sacrifice (Canada) - Rehearsal #2 1985 (Demo)
Sacrifice (Canada) - Forward To Termination 1987 (1988 Metal Blade / Restless 72223-2)
Band / Название Группы: Sacrifice
Album title / Название Альбома : Forward To Termination
Year / Год Выпуска : 1987
Genre / Жанр: Thrash Metal
Country / Страна : Canada
Track list / Список Песен
1. Forward To Termination / Terror Strikes
2. Re-Animation
3. Afterlife
4. Flames Of Armageddon
5. The Entity
6. Forever Enslaved
7. Cyanide
8. Light Of The End
9. Pyrokinesis
Technical info / Технические данные .
Source / Источник : CD
Format / Формат : APE, Insane. Lossless.
Resolution / Разрешение : 44 KHz / 16 Bit
Total playing time / Суммарное время проигрывания : 39:48
Album art / Полиграфия: Booklet, back cover, CD.
Буклет, задняя обложка, диск.
Comment / Комментарий
Ripped from the CD which was released under Metal Blade / Restless.
Срипованно с диска выпущенного под Metal Blade / Restless.
Links / Ссылки
Rapidshare part 1 Rapidshare part 2
Sendspace
Narod
251 MB
PERFORMER "Sacrifice"
TITLE "Forward To Termination"
FILE "Sacrifice (1987) - Forward To Termination.ape" WAVE
    TITLE "Forward To Termination / Terror Strikes"
    INDEX 00 00:00:00
    INDEX 01 00:00:50
    TITLE "Re-Animation"
    INDEX 01 04:30:10
    TITLE "Afterlife"
    INDEX 01 08:19:62
    TITLE "Flames Of Armageddon"
    INDEX 00 12:32:32
    INDEX 01 12:33:27
    TITLE "The Entity"
    INDEX 00 20:21:15
    INDEX 01 20:22:22
    TITLE "Forever Enslaved"
    INDEX 01 26:06:22
    TITLE "Cyanide"
    INDEX 01 29:15:30
    TITLE "Light Of The End"
    INDEX 00 32:52:17
    INDEX 01 32:53:07
    TITLE "Pyrokinesis"
    INDEX 00 37:41:02
    INDEX 01 37:42:12
EAC extraction logfile from 8. July 2009, 10:44 for CD
Sacrifice / Forward To Termination
Used drive  : ASUS    DRW-1814BLT   Adapter: 3  ID: 0
Read mode   : Secure with C2, accurate stream, disable cache
Read offset correction : 6
                     44.100 Hz; 16 Bit; Stereo
                     Use compression offset : 0
Other options      :
     Filename F:\Vinyl ; CD ; Tape Rips\CDImage.wav
     CRC 62D7CFC9
No errors occured
Death The Ultimate Reality
PostPosted: 12 Aug 2012
Ок, вопросов пока нет :dance:
Спасибо Наташе за рип :thanx:
зы. Про остальное я не забыл, еще в процессе всё... :esel:
PostPosted: 26 Oct 2014
Lоcаtion: Киев
Sacrifice (Canada) - Live Detroit 1987.avi
Necronomicon
Re-Animation
Turn In Your Grave
Flames of Armageddon
Pyrokinesis
Homicidal Breath
Forward To Termination-Terror Strike
Burned At The Stake
The Entity
Afterlife
Forever Enslaved
Total time: 51min.17s.
Image Image Image Image Image Image
происхождение:
В своё время выдернуто с Гитарс 101. Бутлежная самопальная съёмка на видеокамеру.Изображение достаточно туманное и размытое, как положено для таких бутылей,однако всё дополняет звук прописанный с микрофона напрямую,разогретые до красна Маршаллы и железно визжащие Ибанезы создают 100% атмосферу трэшевого погрома.Конкретный звук 80-х.
media info:
Sacrifice - Live Detroit '87.avi
Format : CDXA/MPEG-PS
File size : 521 MiB
Duration : 51mn 17s
Overall bit rate : 1 420 Kbps
Writing library : encoded by TMPGEnc (ver. 2.59.47.155)
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Duration : 51mn 17s
Bit rate : 1 167 Kbps
Maximum bit rate : 1 150 Kbps
Width : 352 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.461
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 428 MiB (82%)
Writing library : TMPGEnc 2.59.47.155
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 51mn 17s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 82.2 MiB (16%)
https://yadi.sk/i/phoSUUjUcJYpo
PostPosted: 27 Oct 2014
mirror: Narod l M-Cloud
PostPosted: 15 Aug 2015
Ищу
Sacrifice (Canada) - Torment In Fire 1985 (1991 Fringe reissue)
1991 Fringe reissue
Cat. numb.: FPD3020
Tracklist
1 The Awakening
2 Sacrifice
3 Turn In Your Grave
4 Homicidal Breath
5 Warrior Of Death
6 Infernal Visions
7 Burned At The Stake
8 Necronomicon
9 The Exorcism
10 Possession
11 Decapitation
12 Beyond Death
PostPosted: 10 Jul 2016
Ищу в любом качестве...
Sacrifice [CAN] - Rehearsal #2 1985 (Demo)
1. The Four Horsemen (Metallica cover)
2. Violence and Force (Exciter cover)
3. Creeping Death (Metallica cover)
4. Turn in Your Grave
5. Crionics (Slayer cover)
This is the second Sacrifice demo/rehearsal, released in January '85. :arrov: http://www.metal-archives.com/albums/Sa ... %232/56127
Висяк...
PostPosted: 11 Jul 2016
Начав издалека, сразу был послан... Спросил про самую первую репетицию...
Sacrifice wrote:
very first ? probably not as i would have no idea were that could be or if even exists anymore
Теперь самое время переспросить и про искомую... Но ответ предсказуемо очевиден...
PostPosted: 12 Jul 2016
Вопрос по второй демке вызвыл гомерический смех...
Sacrifice wrote:
Hahahaha wow i dont even remember that . Nice Find !!
Теперь надо из принципа найти и порадовать старичков...
Эт ты какую жжжыырную демку ищешь :shok:
Ну я так понял что ни первой ни второй пока не нашлось. :fingal:
какая-то из демок у меня была, 87 или 89, наверное
boojum
студийные демки они переиздал на цд, записи с репетиций найти б.
Кирилл говорит верно, поздние демы есть на переизданиях от Marquee + куча бутлежного материала...
Экзорсизм :arrov: http://www.metal-archives.com/albums/Sa ... ire/431247
FTT :arrov: http://www.metal-archives.com/albums/Sa ... ion/460567
Демо '89 :arrov: http://www.metal-archives.com/albums/Sa ... une/460572
Рехерсалс #2 ценна коврами... сами же видите, что там творится с трек-листом...
Так-с... послали меня к некому Robin-у Dudley-ю... пошёл... :kro:
Шедевр!.. :lob:
SACRIFICE - Truth (After The Rain) | +
PostPosted: 14 Jul 2016
Schmelzer wrote:
Звучание понравилось, в принципе мне звучание дисков с pre-emph флагом как-то по приятней кажется (пропущенное через convolver конечно), не знаю даже как объяснить.
У меня есть второе издание от Restless/Metal Blade. Тоже раритет. Но звучит хуже чем Fringe.
Кто-нибудь сравнивал?.. Правда что ли, звучит лучше американского диска?.. :arrov: viewtopic.php?p=59843#p59843
Дабы тема не пропадала, придал ей новый окрас... По сути она в своё время являлась нарушением правила о запрете запросов релизов текущего и прошедшего годов... Странно, что никого не пожурили в то время... :oops:
Но вот теперь, можно дружно поискать канадский первопресс от Sonic Unyon Records, поскольку видимо остальное не совсем и рар теперь...
PostPosted: 08 Jul 2017
VARVAAR wrote:
Ищется канадский цид!
Sacrifice (Canada) - The Ones I Condemn 2009 (Sonic Unyon SUNCD1242)
Everhard wrote:
Ищу
Вопрос ко всем троим, продолжаем ли поиск?..
Я свой запрос подтверждаю... Запрос Михаила мне тоже интересен из-за бонуса 11. Anthem (Rush cover bonus), а то он у меня в слабеньком качестве каком-то... :oops:
Как хорошо, что есть перезаливки дохлых файлов в топике :kro:
Это от Мишани который?
Меня больше волнует торчащее ЗДЕСЬ концертное видео :fingal: :fingal: :fingal:
:arrow: :lloo: :esel:
Yt n ckjd/ Pfxtv njulf ye;ys djj,ot hfpltks yf ajhewvt&&&&&&&&
