It is currently 22 Apr 2026
Post new topic Reply to topic  [ 111 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: 08 Jul 2009
Lоcаtion: Таллин, Эстония.
Sacrifice (Canada) - Torment In Fire 1985 (1991 Fringe FPD3020)
Sacrifice (Canada) - Rehearsal #2 1985 (Demo)
Sacrifice (Canada) - Forward To Termination 1987 (1988 Metal Blade / Restless 72223-2)
Band / Название Группы: Sacrifice
Album title / Название Альбома : Forward To Termination
Year / Год Выпуска : 1987
Genre / Жанр: Thrash Metal
Country / Страна : Canada
Track list / Список Песен
1. Forward To Termination / Terror Strikes
2. Re-Animation
3. Afterlife
4. Flames Of Armageddon
5. The Entity
6. Forever Enslaved
7. Cyanide
8. Light Of The End
9. Pyrokinesis
Technical info / Технические данные .
Source / Источник : CD
Format / Формат : APE, Insane. Lossless.
Resolution / Разрешение : 44 KHz / 16 Bit
Total playing time / Суммарное время проигрывания : 39:48
Album art / Полиграфия: Booklet, back cover, CD.
Буклет, задняя обложка, диск.
Comment / Комментарий
Ripped from the CD which was released under Metal Blade / Restless.
Срипованно с диска выпущенного под Metal Blade / Restless.
Links / Ссылки
Rapidshare part 1 Rapidshare part 2
Sendspace
Narod
251 MB
PERFORMER "Sacrifice"
TITLE "Forward To Termination"
FILE "Sacrifice (1987) - Forward To Termination.ape" WAVE
    TITLE "Forward To Termination / Terror Strikes"
    INDEX 00 00:00:00
    INDEX 01 00:00:50
    TITLE "Re-Animation"
    INDEX 01 04:30:10
    TITLE "Afterlife"
    INDEX 01 08:19:62
    TITLE "Flames Of Armageddon"
    INDEX 00 12:32:32
    INDEX 01 12:33:27
    TITLE "The Entity"
    INDEX 00 20:21:15
    INDEX 01 20:22:22
    TITLE "Forever Enslaved"
    INDEX 01 26:06:22
    TITLE "Cyanide"
    INDEX 01 29:15:30
    TITLE "Light Of The End"
    INDEX 00 32:52:17
    INDEX 01 32:53:07
    TITLE "Pyrokinesis"
    INDEX 00 37:41:02
    INDEX 01 37:42:12
EAC extraction logfile from 8. July 2009, 10:44 for CD
Sacrifice / Forward To Termination
Used drive  : ASUS    DRW-1814BLT   Adapter: 3  ID: 0
Read mode   : Secure with C2, accurate stream, disable cache
Read offset correction : 6
                     44.100 Hz; 16 Bit; Stereo
                     Use compression offset : 0
Other options      :
     Filename F:\Vinyl ; CD ; Tape Rips\CDImage.wav
     CRC 62D7CFC9
No errors occured
Death The Ultimate Reality
Спасибо :true:
PostPosted: 09 Jul 2009
Спасибо!!!
а что значит Insane?
-=KazgorotH=- wrote:
Insane?
это (наскольок я помню) максимальная степень сжатия в манки аудио. мой процессор 2500 атлон зависал на 20 минут, но таки сжимал в манки аудио альбом, при этом по сравнению с методом сжатия High выигрывалось аж 5 мегабайт . О как :true:
посмотри на мой аватар :crazy:
всё мне ясно стало теперь (с) :crazy:
видишь, Артем, как надо правильно объяснять? желательно с картинкаме :oops:
MetalMilitia
Роман, дружище, прости за флуд и спасибо за труды :thanx:
Пожалуйста ребяты ! Добавил ссылочку где целым куском файл лежит. У меня проц 5600 + Дуал Кор, минут 7 / 8 жмёт. А при проигрывании секнуд 5 лаг, при переключении песен.
PostPosted: 12 Jul 2009
Ищется канадский цид!
Sacrifice (Canada) - The Ones I Condemn 2009 (Sonic Unyon SUNCD1242)
Image Image Image
1. We Will Prevail 02:18
2. The Ones I Condemn 03:22
3. Give Me Justice 03:27
4. The Great Wall 04:45
5. Tetragrammaton 05:24
6. Atrocity 03:55
7. Hiroshima 04:19
8. The Devil's Martyr 02:36
9. Ultimate Power Corrupts 03:21
10. Desolation Alive 07:19
11. Anthem (Rush cover bonus) 04:26
я тут,хотя бы в мп3 найти не могу... :oops:
PostPosted: 13 Jul 2009
Не ,мр3 не нужно. Нужен лось со сканами , диск ведь только что вышел .
PostPosted: 25 Jul 2009
Хочу тоже! :) Special особенно!
PostPosted: 23 Aug 2009
Прослушал. Олдскул 100%. Thrash-хит , каждая композиция. Но!!! Год то сейчас 2009 , и надо бы как то сочетать что ли , старое звучание с какими нибудь новыми «штучками». Пару – тройку новых звуковых идей, я думаю, сделали бы эту пластинку гораздо интереснее и притягательнее. Разумеется если с этими идеями не перебарщивать , сохраняя общую картину олдскульного звучания.
Впрочем , как бы не хороши были композиции на этом альбоме , сделать что либо лучше композиции “Sacrifice” с Torment in fire , группе и раньше , и теперь не удалось.
PostPosted: 10 Sep 2009
На торренте выложили , потрековый рип., без сканов, но хоть не мр3.
http://torrents.ru/forum/viewtopic.php? ... 1#26177101
PostPosted: 24 Sep 2009
http://strutter.moole.ru/68002-sacrific ... ndemn.html
Ура, CRUSADER начал снова заливать :true:
Скачал...Но пока еще не послушал.
Сканы есть? Или это таже перезаливка с торрента ?
Тоже потрековый без сканов.Послушал и не понял...
хреново, ждёмс правильный рип со сканами.
PostPosted: 13 Feb 2010
:arrow:
