It is currently 18 Aug 2026
PostPosted: 14 Dec 2016
Вот такая кассетка:
https://www.discogs.com/Metal-Church-Me ... se/2111764
Mне её одолжил один цапан. Очевидно, она пролежала на солнце и корпус слегка расплавился так, что в деку не вставлялся. Достал ленту и вставил сначала в Maxell. Кассета плыла. Потом в TDK. Кассета плыла на дорогих деках: Сонька и Onkyo. Но на 2х кассетной деке Technics RS-TR313 вроде нормально прошло. Итак 2 варианта. Один оцифрован с первой деки, 2ой со второй. На 2ой деке позвонче звучит. Никаких преобразований кроме фейдов не производил. Так и оставил в 24/44.1.
Кассетник: Technics RS-TR313 (дека 2ая и 1ая - обе в reverse направлении).
АЦП: M-Audio Audiophile 2496.
10. Big Guns
Ссылка:
https://we.tl/T3sfFgotYa
PostPosted: 15 Dec 2016
Lоcаtion: Serbia
Ну и как звучок?
ЗЫ. Может скоро сюрприз раритетный приготовлю.
Lоcаtion: Serbia
Pretty good,better than on vinyl. Vinyl version has a lot of distortion
Do yo have Sabbat's history of time to come US press? First song on German press has some dropouts.I was wondering does US press have these problems?
Where did you get the vinyl version? From Revici? That's the last song, so in Revici case there will always be distortion. Now which one of my 2 versions sounds better? From deck 1 or from deck 2? I called the deck 1 version inferior - I thought it was lacking highs. And it's faster also.
Yes, I do have Sabbat's debut. Have I not uploaded it? Can you check the lossless section?
If you can tell me the dropout spot, I can check for you. Is it the 1st track called Intro?
Lоcаtion: Serbia
There is another one from thrashmageddon which also has distortion.steamhammer vinyl is not of the greatest quality.
Second version is better to me too. Can you fix the speed issue, please?
I can't find your rip of history of time to come here
Dropout is in the 1st real song.ill check today and let you know.
PostPosted: 18 Dec 2016
Lоcаtion: Serbia
In A Cautionary Tale from 3.26 and onwards
PostPosted: 19 Dec 2016
I haven't noticed any dropouts.
PostPosted: 20 Dec 2016
Lоcаtion: Serbia
Great! Please post your version , when you can, please. :thanx:
Ну и как звучок?
Пока не слушал. Очередь образовалась.
У меня явно где-то может валятся рип с Трашмага. Он тоже скачал и валяется :pardon:
Я не к тому, что не нужно вообще ничего рипать и звук получше искать, но просто чую, что многим глубоко пофиг, как звучит этот альбом сейчас. Мы все помним, что звучал от для того времени вполне нормально и искать саунд получше или самому его выделывать, вылизывать, по-моему это мартышковый труд.
Хотя, если хочется, то никто ж не против. Но и чуть ли не требовать мнговенной оценки рипа, это пардон тоже не очень лепо.
И ещё. Лёнь, а попробуй вот такой файлообменник заюзать, плиз :arrow: https://drop.me
Ну и как звучок?
Я ничо не требую. Я чифирнул только 1 трек, который вошел в альбом только на Банзай кассете и SPV виниле.
Опа. А я только сие заметил... :oops:
Шикарные колготки у Марлея на фотке :ok:
Гы.
Андрюша, я ж написал, что только Big Guns чифирнулул. Но скан сделал всей кассетки. Если хочешь скан только того места, где написан Big Guns, спецом для тебя перезалью.
PostPosted: 21 Dec 2016
мне больше понравился звук с винила (рип Ревичи). слушал на обычных компьютерных колонках
я здесь
TG
MAX
PostPosted: 24 Dec 2016
Ну и как звучок?
Нормальный :thanx:
Причём на обоих вариантах. Жду сюрприза в виде полного альбома? :kro:
А я уже рипнул его и выложил в первое сообщение :dance:
Ну и как звучок?
Нормальный :thanx:
- Абрам Соломонович, как ваше здоровье?
- Не дождётесь!
Ну в принципе такой же ответ. Не имеет смысла, ибо кассета звучит гораздо хуже CD. То есть настолько хуже, что ее под цыд не подгонишь.
Я может как нибудь очифирну SPV винил, если мне его дадут.
