It is currently 26 Apr 2024
PostPosted: 22 Apr 2016
VA [1989] Ultimate Revenge 2 [comp] [flac] [tracks+cue+log+scans]
Place Of Origin: Various
Release Year: 1989
Ripping Source: CD
Label: Combat
Catalog Number: 88561-2002-2
Tracklisting:
01 - Forbidden - As Good As Dead
02 - Forbidden - Chalice Of Blood
03 - Faith Or Fear - Lack Of Motivation
04 - Faith Or Fear - Time Bomb
05 - Faith Or Fear - Punishment Area
06 - Death - Open Casket
07 - Death - Choke On It
08 - Dark Angel - Merciless Death
09 - Perish In Flames / Darkness Descends
10 - Raven - Into The Jaws Of Death
11 - Raven - Gimme A Break
EAC log | +
Code:
EAC extraction logfile from 2. December 2014, 18:01
Various / Ultimate Revenge 2
Used drive  : ASUS DVDRAM GHB1N   Adapter: 3  ID: 0
Read mode               : Secure
Defeat audio cache      : Yes
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.33 |  4:09.40 |        33    |    18747
        2  |  4:09.73 |  4:49.22 |     18748    |    40444
        3  |  8:59.20 |  3:26.28 |     40445    |    55922
        4  | 12:25.48 |  5:11.60 |     55923    |    79307
        5  | 17:37.33 |  5:06.12 |     79308    |   102269
        6  | 22:43.45 |  4:49.05 |    102270    |   123949
        7  | 27:32.50 |  5:57.48 |    123950    |   150772
        8  | 33:30.23 |  3:44.05 |    150773    |   167577
        9  | 37:14.28 |  8:31.07 |    167578    |   205909
       10  | 45:45.35 |  5:35.30 |    205910    |   231064
       11  | 51:20.65 |  3:29.50 |    231065    |   246789
Track  1
     Filename D:\!EAC\VA - Ultimate Revenge 2\01 - Forbidden - As Good As Dead.wav
     Pre-gap length  0:00:02.33
     Peak level 99.1 %
     Extraction speed 1.0 X
     Test CRC CD880FCA
     Copy CRC CD880FCA
     Accurately ripped (confidence 2)  [6B056EC9]  (AR v2)
Track  2
     Filename D:\!EAC\VA - Ultimate Revenge 2\02 - Forbidden - Chalice Of Blood.wav
     Peak level 82.6 %
     Extraction speed 1.2 X
     Test CRC C259573A
     Copy CRC C259573A
     Accurately ripped (confidence 2)  [09FDC657]  (AR v2)
Track  3
     Filename D:\!EAC\VA - Ultimate Revenge 2\03 - Faith Or Fear - Lack Of Motivation.wav
     Pre-gap length  0:00:00.60
     Peak level 89.5 %
     Test CRC 5E2F58BC
     Copy CRC 5E2F58BC
     Accurately ripped (confidence 2)  [73BCDA15]  (AR v2)
Track  4
     Filename D:\!EAC\VA - Ultimate Revenge 2\04 - Faith Or Fear - Time Bomb.wav
     Peak level 88.1 %
     Extraction speed 1.4 X
     Test CRC A9ACE879
     Copy CRC A9ACE879
     Accurately ripped (confidence 2)  [820F0DAC]  (AR v2)
Track  5
     Filename D:\!EAC\VA - Ultimate Revenge 2\05 - Faith Or Fear - Punishment Area.wav
     Peak level 88.2 %
     Extraction speed 1.5 X
     Test CRC 82C556CC
     Copy CRC 82C556CC
     Accurately ripped (confidence 2)  [F47C030C]  (AR v2)
Track  6
     Filename D:\!EAC\VA - Ultimate Revenge 2\06 - Death - Open Casket.wav
     Pre-gap length  0:00:00.43
     Peak level 97.9 %
     Extraction speed 1.6 X
     Test CRC 7978BB97
     Copy CRC 7978BB97
     Accurately ripped (confidence 2)  [6F41CF6B]  (AR v2)
Track  7
     Filename D:\!EAC\VA - Ultimate Revenge 2\07 - Death - Choke On It.wav
     Peak level 89.0 %
     Extraction speed 1.8 X
     Test CRC 057C164A
     Copy CRC 057C164A
     Accurately ripped (confidence 2)  [5CAFCE4D]  (AR v2)
Track  8
     Filename D:\!EAC\VA - Ultimate Revenge 2\08 - Dark Angel - Merciless Death.wav
     Peak level 79.1 %
     Track quality 99.9 %
     Test CRC 7934E01E
     Copy CRC 7934E01E
     Accurately ripped (confidence 2)  [ADD79BED]  (AR v2)
Track  9
     Filename D:\!EAC\VA - Ultimate Revenge 2\09 - Dark Angel - Perish In Flames Darkness Descends.wav
     Peak level 83.1 %
     Extraction speed 2.0 X
     Test CRC 4EAEFA13
     Copy CRC 4EAEFA13
     Accurately ripped (confidence 2)  [737D7953]  (AR v2)
Track 10
     Filename D:\!EAC\VA - Ultimate Revenge 2\10 - Raven - Into The Jaws Of Death.wav
     Pre-gap length  0:00:01.32
     Peak level 98.2 %
     Extraction speed 2.1 X
     Test CRC 60F9D227
     Copy CRC 60F9D227
     Accurately ripped (confidence 2)  [444601CE]  (AR v2)
Track 11
     Filename D:\!EAC\VA - Ultimate Revenge 2\11 - Raven - Gimme A Break.wav
     Peak level 79.1 %
     Test CRC F48506A1
     Copy CRC F48506A1
     Accurately ripped (confidence 2)  [41D0F30A]  (AR v2)
All tracks accurately ripped
==== Log checksum A9C58C872B368DB06DCDA7AD423A30886E73D9FCCCF846E2ABF918C530753B15 ====
Lоcаtion: Serbia
:thanx: :thanx: :thanx: :thanx:
