It is currently 05 May 2024
PostPosted: 04 Apr 2010
Vektor - Black Future 2009
Heavy Artillery Records (HA5-5012-2-4)
Genre: progressive thrash metal
Country: USA
Contents: flac/cue/log/scans
01. Black Future
02. Oblivion
03. Destroying The Cosmos
04. Forests Of Legend
05. Hunger For Violence
06. Deoxyribonucleic Acid
07. Asteroid
08. Dark Nebula
09. Accelerating Universe
Playtime: 68:06
Lineup:
David Disanto - vocals and guitars
Erik Nelson - guitars
Frank Chin - bass
Blake Anderson - drums
EAC log
Code:
EAC extraction logfile from 3. April 2010, 23:19
Vektor / Black Future
Used drive  : Optiarc DVD RW AD-7240S   Adapter: 2  ID: 0
Read mode               : Secure
Defeat audio cache      : Yes
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Sample format      : 44.100 Hz; 16 Bit; Stereo
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  5:03.33 |         0    |    22757
        2  |  5:03.33 |  4:54.01 |     22758    |    44808
        3  |  9:57.34 |  6:47.28 |     44809    |    75361
        4  | 16:44.62 | 10:16.42 |     75362    |   121603
        5  | 27:01.29 |  5:30.52 |    121604    |   146405
        6  | 32:32.06 |  4:45.58 |    146406    |   167838
        7  | 37:17.64 |  6:49.18 |    167839    |   198531
        8  | 44:07.07 | 10:28.44 |    198532    |   245675
        9  | 54:35.51 | 13:31.19 |    245676    |   306519
     Filename D:\spiralarch\Vektor - Black Future.wav
     Copy CRC 6CD0DFF0
AccurateRip summary
Track  1  not present in database
Track  2  not present in database
Track  3  not present in database
Track  4  not present in database
Track  5  not present in database
Track  6  not present in database
Track  7  not present in database
Track  8  not present in database
Track  9  not present in database
Одного взгляда на лого достаточно для того, чтобы понять источник вдохновения этих ребят. Причем они достаточно самобытны. Это не клон Voivod, не надейтесь. :crazy: Т.е. если вам, например, не нравится Voivod, но нравится Destruction, то я бы тоже не проходил мимо.
Кто-то когда-то меня про них спрашивал... :oops:
Кто-то его в марте с другого места качнул... :oops:
metallpaparazzy
Lоcаtion: Днепропетровск
о, а я думал спросить :oops:
качну обязательно, албум 2006 года меня чем-то цепонул. :true:
а не в курсе, дэмка 2003 года путняя?
дык это ж не тру :crazy:
PostPosted: 05 Apr 2010
В конце 80-х я за винилами Voivod охотился с маниакальной настойчивостью, и всегда их ставил в один ряд с Метлой , Энтрэкс и Слайер. Заметьте , все 4 группы играли thrash metal совершенно по разному! И все они были тру!
Спасибо Олег за Vektor, качаю в ослике, торопиться некуда , всё одно нет выходных , что бы прослушать........Ты WS скачал?
Превосходный техно-трэшевый релиз от молодой американской группы. Ребята явно увлечены творчеством Voivod, что чувствуется и по логотипу, и по научным текстам, и по музыке. Однако, в отличие от канадцев, в музыке Vektor меньше авангардных моментов и больше яркой мелодики. Именно войводовские мотивы, кстати, слышны на двух последних треках – там как раз есть место некой астральности и чуть-чуть авангардизма.
Также музыка несколько похожа на творчество Dearthrow, Death и Sadus. Композиции достаточно навороченные, но не чрезмерно, в каждой по несколько разноплановых частей. Темп исполнения в основном быстрый. Соляки во многом напоминают мелодик дэтовские. Вокал – прихаршеванный скриминг, напоминающий Шмира и это единственное, что мне не слишком понравилось на альбоме. Все остальное выше всяких похвал, отличная умная, скоростная и вместе с тем мелодичная музыка. Выделить какую-то композицию сложно, так как все их них достойны внимания для ценителей интеллектуального трэша. Один из лучших релизов тяжелой музыки последнего времени. 5.2/6.0.
11.03.2010.
Conceived by front man and guitarist David DiSanto, a spark of energy gave rise to Vektor in late 2004. With the addition of lead shredder Erik Nelson, the band began playing shows around the local Phoenix area in 2005. Implementing technical, speed thrash, and progressive influences, Vektor quickly found their own unique sound, setting them apart from the rest of the Phoenix metal scene. The band soon made a name for themselves throughout the southwestern United States, playing local shows and opening for national acts such as Testament, Sigh, Sonata Arctica, Hirax, Finntroll, Dark Tranquility, Firewind, Iced Earth, Unexpect and Municipal Waste.
Vektor released their self-financed CD entitled "Demolition" in early 2006, generating a massive response throughout the metal underground and earning the band a growing contingent of die-hard fans. In 2007 the band followed up with the two-track "Hunger for Violence" demo to even greater fanfare, putting the band on the radar of many international fans for the first time. In search of the perfect rhythm section to complete their vision, Vektor's line-up continued to evolve throughout 2008, before finding drummer Blake Anderson and bassist Frank Chin, finally cementing the ideal like-up to realize their goal of galactic conquest.
Refusing to be pigeon-holed into any metal sub-genre, Vektor employs an array of intricacy, virtuosity and a wholly unique sound which few others can claim. Diabolical space metal? Prog? Jazz fusion? You decide. Welcome to the future; prepare to have your brains melted.
Согласен. Перекачиваю :true:
mirror: MultiUp l Narod
и дальше...
Миш это чего было, твоя рецуха?
труъ антисионист
Слушал я этих ребят, по мне так не совсем техно, но однозначно трешь. Причём трешь чисто европейский, то есть агрессивный и злобный, мне очень сильно напонил дестракшн. :true:
от дестракшн только вокал. ну может 88-90 годы немного напоминает. Vektor - гораздо боле интеллектуальная и мелодичная музыка.
PostPosted: 10 Aug 2011
ТрэшЭрос
Lоcаtion: Гулькевичи
Thrash no trash!!!
PostPosted: 06 Dec 2011
Не люблю тему плодить, потому рецензии здесь помещу
Vektor – Demolition [demo] (2006)
1. Spiral Galaxy 01:13
2. Oblivion 04:35
3. Fast Paced Society 06:56
4. Venus Project 07:31
5. Destroying the Cosmos 07:15
6. Infiltration 00:56
7. Moonbase 12:55
8. Tetrastructural Minds 06:56
Total: 48:17
Дебютный альбом американской группы, ныне рассматриваемый как демка. Это и понятно, т.к. практически уже весь материал (кроме коротких инструменталок и Moonbase) был в дальнейшем перезаписан для последующих дисков коллектива, отшлифован и доведен дл ума. А музыка, в принципе, та же, Technical Thrash Metal, с космической тематикой, основанный прежде всего на творчестве Voivod, но более мелодичный и с использованием харш-вокала, местами со скримингом. Материал очень достойный, умный, техничный, но звучит по сравнению с новыми версиями довольно сыро и несколько неярко. По сути, сейчас наиболее интересна нереализованная композиция Moonbase, самая сложная и разноплановая. Надеюсь, что Векторовцы её также в дальнейшем доведут до ума. А наиболее же яркое впечатление оставляет последний трек Tetrastructural Minds, впрочем и он звучит лучше на Outer Isolation.
Отличная работа для своего времени, но группа постоянно растет и совершенствуется, так что рекомендую в первую очередь именно номерные альбомы Vektor. 5.0/6.0.
06.12.2011.
Vektor - Outer Isolation (2011)
1. Cosmic Cortex 10:23
2. Echoless Chamber 05:15
3. Dying World 05:19
4. Tetrastructural Minds 05:21
5. Venus Project 06:47
6. Dark Creations, Dead Creators 03:25
7. Fast Paced Society 06:45
8. Outer Isolation 08:28
Total: 51:43
Второй официальный полноформатник. Практически безупречный релиз, Technical Thrash Metal с яркими мелодичными ходами. Основы всё те же, Voivod, Mekong Delta, Death, но группа всё больше отдаляется от собственно творчества канадцев и это по мне хорошо. Вокалист (он же второй гитарист) David DiSanto поёт харшевым хрипящим скримингом, и только это я могу отнести к недостаткам диска.
Все композиции великолепны, темп исполнения весьма и весьма быстрый, лишь с редкими неспешными и нетяжелыми вкраплениями. Частые смены ритмических рисунков и структур, однако, всё заморочено в меру, и при этом постоянные головокружительные мелодичные соляки, что выгодно отличает Vektor от остальных техно-трэшеров. Перезаписанные старые вещи Fast Paced Society, Venus Project и Tetrastructural Minds звучат тут на порядок интереснее, чем на Demolition, группа заметно прибавила с тех времен. Ощутим и прогресс по сравнению с прошлой замечательной работой Black Future. Похоже, что Outer Isolation имеет все шансы у меня стать лучшим альбомом 2011 года, несмотря на то, что это вовсе не Power). 5.4/6.0.
06.12.2011.
PostPosted: 05 Jul 2012
Вот и я подобрался к альбому...
Больше всего соглашусь с заметками Егора:
Здесь всё очень метко подмечено в сравнениях. Но я бы еще добавил сюда же частичку голоса от Сабины Классен и какие-то не очень приятные блэковые повизгивания и напор. И некую атмосферность.
Кабы не высокая техничность альбома (особенно лидер-гитариста), можно бы этот скоростной релиз, а по сути - просто рубилово, назвать техничным же трэш-блэком с футуристической лирикой =)
6+/10
Почем не 7 или 8?
А мне очень здесь не хватает громогласных бэков :( Или хотя бы хриплых выкриков, как в хардкоре.
Блин, зачастую они, особенно в припевах, так просятся, что нимагу. Но... вокалист пытается сам всё проорать и сбивается на визг :fingal:
зы. А вообще, альбом произвел впечатление сверхзвукового самолёта, который пролетел над вами, когда вы в чистом поле присели мирно и с расстановкой покакать, почитывая старую прессу, и тут вдруг - вжик... :leo: а портки то уже запачканы :esel:
PostPosted: 06 Jul 2012
Как-то вроде тоже самое, логическое продолжение предыдущего альбома, а вроде и еще техничнее стала музыка группы.
Но... сорри, за полдня этот альбом мне надоел до жути, что сказать что-то новое уже нет сил...
Вернусь к нему как-то попозже.
6+/10
ps. Для активных качальщиков - ссылка на лося-11 в этом сообщении спрятана.Так что водите мышкой активно :cow:
вот как раз хардкорных выкриков точно тут не надо.
Но оценка, Андрей, маловатая ( Каждому, конечно, свое, я вот вообще не понимаю твои восхищения каким-нибудь простеньким хардом 80-х, который с середины первый песни альбома вызывает у меня желание вырубить его.
А техничность и мелодичность, помноженную на скорость я всегда приветствую - это то, что я наиболее ценю в музыке.
Одна из немногих молодых трешевых банд, на которую подсел :pray: Нравится всё - и напор и агрессивность и манера вокальная с визгами а-ля Шмир, и заигрывания с Воиводами. Совершенно не утомляет. Часто переслушиваю их эти два альбомчика, да и демка неплоха была. :meloman:
Да группа мне понравилась, но... не полностью =)
Отложил до более прохладных времён альбомы. А тов такую погоду ничо тяжелее хэви слушать не могу :esel:
