It is currently 09 Apr 2026
PostPosted: 02 Aug 2009
Группа: V8
Альбом: Un Paso Más en la Batalla
Год: 1984
Лейбл: Umbral
Стиль: Heavy Metal
Страна: ARG
Формат: Image APE / LOG / CUE
Line Up:
Alberto "Beto" Zamarbide - Vocals
Osvaldo Civile - Guitar
Ricardo Iorio - Bass
Gustavo Rowek - Drums
Tracks:
01. Deseando Destruir Y Matar (5:16)
02. Siervos Del Mal (3:26)
03. La Mano Maldita (2:23)
04. Cautivos Del Sistema (3:53)
05. Lanzado Al Mundo Hoy (3:53)
06. Ideando La Fuga (2:57)
07. Camino Al Sepulcro (4:22)
08. Momento De Luchar (2:54)
LOG
EAC extraction logfile from 21. March 2009, 18:19
V8 / Un Paso Mas En La Batalla
Used drive : Optiarc DVD RW AD-7190A Adapter: 1 ID: 0
Read offset correction : 102
Selected bitrate : High Lossless Compression
Add ID3 tag : Yes
Command line compressor : C:\Archivos de programa\Exact Audio Copy\MAC.EXE
1 | 0:00.00 | 5:16.31 | 0 | 23730
2 | 5:16.31 | 3:26.08 | 23731 | 39188
3 | 8:42.39 | 2:23.23 | 39189 | 49936
4 | 11:05.62 | 3:53.15 | 49937 | 67426
5 | 14:59.02 | 3:53.19 | 67427 | 84920
6 | 18:52.21 | 2:56.39 | 84921 | 98159
7 | 21:48.60 | 4:21.55 | 98160 | 117789
8 | 26:10.40 | 2:53.42 | 117790 | 130806
Filename C:\Documents and Settings\Administrador\Escritorio\Metal4alas.blogspot.com\CD 2 - Un Paso Mбs En La Batalla (1984\V8 - Un Paso Mas En La Batalla.wav
Peak level 97.7 %
Copy CRC 27C82572
===================================DOWNLOAD========================================
http://www.megaupload.com/?d=UWM33CD3
http://narod.ru/disk/11533003000/V8%20- ... a.zip.html
