It is currently 04 Aug 2026
PostPosted: 02 Aug 2009
Группа: V8
Альбом: Luchando por el Metal
Год: 1983
Лейбл: Umbral
Стиль: Heavy Metal
Страна: ARG
Формат: Image APE / LOG / CUE
Line Up:
Alberto "Beto" Zamarbide - Vocals
Osvaldo Civile - Guitar
Ricardo Iorio - Bass
Gustavo Rowek - Drums
Tracks:
01. Destrucciуn (2:08)
02. Parcas Sangrientas (2:58)
03. Si Puedes Vencer al Temor (6:11)
04. Бngeles de las Tinieblas (2:34)
05. Tiempos Metбlicos (2:31)
06. Muy Cansado Estoy (3:23)
07. Brigadas Metбlicas (3:05)
08. Torturador (2:27)
09. Hiena de Metal (1:40)
LOG
EAC extraction logfile from 21. March 2009, 18:32
V8 / Luchando por el Metal
Used drive : Optiarc DVD RW AD-7190A Adapter: 1 ID: 0
Read offset correction : 102
Used interface : Installed external ASPI
interface
Selected bitrate : High Lossless Compression
Add ID3 tag : Yes
Command line compressor : C:Archivos de programaExact Audio
CopyMAC.EXE
1 | 0:00.00 | 2:08.32 | 0 | 9631
2 | 2:08.32 | 2:58.00 | 9632 | 22981
3 | 5:06.32 | 6:11.09 | 22982 | 50815
4 | 11:17.41 | 2:33.49 | 50816 | 62339
5 | 13:51.15 | 2:30.70 | 62340 | 73659
6 | 16:22.10 | 3:23.07 | 73660 | 88891
7 | 19:45.17 | 3:04.41 | 88892 | 102732
8 | 22:49.58 | 2:27.01 | 102733 | 113758
9 | 25:16.59 | 1:40.03 | 113759 | 121261
Filename C:Documents and
SettingsAdministradorEscritorioMetal4alas.blogspot.comV8 - Luchando por el
Metal.wav
Peak level 97.7 %
Range quality 99.9 %
Copy CRC A0E540F3
===================================DOWNLOAD========================================
http://www.megaupload.com/?d=JOJ57HG5
http://narod.ru/disk/11534228000/V8%20- ... l.zip.html
PostPosted: 12 Nov 2009
:thanx: :true:
