It is currently 12 Aug 2026
PostPosted: 02 Aug 2009
Группа: V8
Альбом: El Fin De Los Inicuos
Год: 1986
Лейбл:
Стиль: Heavy Metal
Страна: ARG
Формат: Image APE / LOG / CUE
Рип не мой, найден в сети.
Line Up:
Alberto "Beto" Zamarbide - Vocals
Miguel Roldán - Guitar
Ricardo Iorio - Bass
Adrián Cenci - Drums
Tracks:
1. La Gran Ramera 03:10
2. Ciega Ambición 03:34
3. No Enloqueceré 03:39
4. El Vivo Sustento del Inquisidor 04:00
5. Antes que los Viejos Reyes 03:42
6. Salmo nº 58 04:56
7. El Fin de los Inicuos 02:27
8. Trágico Siglo 03:22
9. Reina Ciega 03:55
Total playing time 32:45
LOG
EAC extraction logfile from 21. March 2009, 17:42
V8 / El Fin de los Inicuos
Used drive : Optiarc DVD RW AD-7190A Adapter: 1 ID: 0
Read offset correction : 102
Used interface : Installed external ASPI
interface
Selected bitrate : High Lossless Compression
Add ID3 tag : Yes
Command line compressor : C:Archivos de programaExact Audio
CopyMAC.EXE
1 | 0:00.00 | 3:13.49 | 0 | 14523
2 | 3:13.49 | 3:36.74 | 14524 | 30797
3 | 6:50.48 | 3:40.35 | 30798 | 47332
4 | 10:31.08 | 4:02.68 | 47333 | 65550
5 | 14:34.01 | 3:43.65 | 65551 | 82340
6 | 18:17.66 | 4:58.01 | 82341 | 104691
7 | 23:15.67 | 2:29.19 | 104692 | 115885
8 | 25:45.11 | 3:26.59 | 115886 | 131394
9 | 29:11.70 | 3:57.08 | 131395 | 149177
Filename C:Documents and
SettingsAdministradorEscritorioMetal4alas.blogspot.comV8 - El Fin de los
Inicuos.wav
Peak level 97.7 %
Range quality 99.9 %
Copy CRC 35B0426A
===================================DOWNLOAD========================================
http://narod.ru/disk/11533898000/V8%20- ... s.zip.html
http://www.megaupload.com/?d=PSJZFTEZ
Glot wrote:
LOG
Вовка, не ленись лог засвечивать, плиз.
