Вроде как
этот. A нет, так какой то из них. См. сканы.
Оформите плиз. 5 дней:
https://we.tl/sWysBSl2vQ1. I Profit - 07:05
2. Officer Nice - 05:24
3. Subterfuge - 04:39
4. Engulfed By Flames - 03:54
5. World In A World - 04:11
6. Mentally Afflicted - 05:50
7. Liquid Courage - 05:27
8. Oppressing The Masses - 04:58
TPT:
EAC extraction logfile from 31. May 2016, 23:20
Vio-Lence / Oppressing The Masses
Used drive : PLEXTOR DVDR PX-760A Adapter: 4 ID: 0
Read offset correction : 30
Overread into Lead-In and Lead-Out : Yes
Null samples used in CRC calculations : No
1 | 0:00.32 | 7:04.55 | 32 | 31886
2 | 7:05.12 | 5:23.65 | 31887 | 56176
3 | 12:29.02 | 4:38.48 | 56177 | 77074
4 | 17:07.50 | 3:54.30 | 77075 | 94654
5 | 21:02.05 | 4:11.27 | 94655 | 113506
6 | 25:13.32 | 5:49.38 | 113507 | 139719
7 | 31:02.70 | 5:27.17 | 139720 | 164261
8 | 36:30.12 | 4:58.25 | 164262 | 186636
Filename C:\Shared\rips\Vio-Lence\Oppressing The Masses\Vio-Lence - Oppressing The Masses.wav
Range quality 99.9 %
Copy CRC 407FE7D8
EAC extraction logfile from 31. May 2016, 23:35
Read offset correction : 11202
Gap handling : Appended to next track
Track 8
Filename C:\Shared\rips\Vio-Lence\Oppressing The Masses\08. Oppressing The Masses.wav
Copy CRC BC02E46B
cue
REM GENRE "Thrash Metal"
REM DATE 1990
REM DISCID 6209B808
CATALOG 0075678210525
PERFORMER "Vio-Lence"
TITLE "Oppressing The Masses"
FILE "Vio-Lence - Oppressing The Masses.wav" WAVE
TITLE "I Profit"
INDEX 00 00:00:00
INDEX 01 00:00:32
TITLE "Officer Nice"
INDEX 01 07:05:12
TITLE "Subterfuge"
INDEX 01 12:29:02
TITLE "Engulfed By Flames"
INDEX 01 17:07:50
TITLE "World In A World"
INDEX 01 21:02:05
TITLE "Mentally Afflicted"
INDEX 01 25:13:32
TITLE "Liquid Courage"
INDEX 01 31:02:70
INDEX 01 36:30:12
