It is currently 04 May 2024
PostPosted: 06 Aug 2011
Taylan Ayik (Tur)- Yalniz Hayal - 2005 - Heavy Metal
Turkey,320k cbr mp3
full covers scan
http://www.multiupload.com/YJY9HJS09J
i m using easy cd-da extrator while i m ripping cd
You can make the album in lossless format ...? :oops:
PostPosted: 07 Aug 2011
yes i can make it in lossless without cue + log
if you accept of course!!
because i still dont understand how to use EAC?? :cry:
http://blowfish.be/eac :dance:
ok if i can , i will send thanks :dance:
Successfully setup the program. If you have any difficulties, you can contact - there is someone to help you :dance:
:true: thanks scatter
PostPosted: 08 Aug 2011
:arrow: viewtopic.php?f=209&t=1145
Manual... the Russian-English from Oleg spiralarch :dance:
ok its coming wav +log +cue :true: :thanx:
finally :meloman:
Taylan ayık - yalnız hayal -wav +log +cue.rar (405.98 MB)
http://www.multiupload.com/K6HAQL84M0
О!!!
Ugur, biggest thanks! :true: :thanx:
Ugur, plz, show eac log :pardon:
To check whether you configured the EAC.
I now have no place on your hard drive :fingal: And although others will download and are unlikely to comments :pardon:
i have 255 gb free space no problem Scatter :dance:
log1
Exact Audio Copy V1.0 beta 2 from 29. April 2011
EAC extraction logfile from 8. August 2011, 12:22
Taylan Ayık / yalnız hayal
Used drive : Optiarc DVD RW AD-7260S Adapter: 0 ID: 1
Read offset correction : 48
Gap handling : Not detected, thus appended to previous track
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
1 | 0:00.00 | 5:06.28 | 0 | 22977
2 | 5:06.28 | 4:46.07 | 22978 | 44434
3 | 9:52.35 | 3:15.05 | 44435 | 59064
4 | 13:07.40 | 3:46.58 | 59065 | 76072
5 | 16:54.23 | 3:47.32 | 76073 | 93129
6 | 20:41.55 | 4:45.60 | 93130 | 114564
7 | 25:27.40 | 3:56.52 | 114565 | 132316
8 | 29:24.17 | 4:05.01 | 132317 | 150692
9 | 33:29.18 | 3:58.66 | 150693 | 168608
10 | 37:28.09 | 3:34.46 | 168609 | 184704
11 | 41:02.55 | 4:34.05 | 184705 | 205259
12 | 45:36.60 | 3:53.50 | 205260 | 222784
Track 1
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\01 Track01.wav
Extraction speed 2.6 X
Copy CRC 207020E3
Accurately ripped (confidence 2) [603A39A6] (AR v1)
Track 2
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\02 Track02.wav
Extraction speed 2.7 X
Copy CRC 6C25B71B
Accurately ripped (confidence 2) [46CDEF59] (AR v1)
Track 3
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\03 Track03.wav
Peak level 99.7 %
Extraction speed 2.8 X
Copy CRC BD8C0FDD
Accurately ripped (confidence 2) [73BFDDCE] (AR v1)
Track 4
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\04 Track04.wav
Peak level 99.6 %
Extraction speed 3.1 X
Copy CRC FA9B23EB
Accurately ripped (confidence 2) [24DAEF86] (AR v1)
Track 5
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\05 Track05.wav
Extraction speed 2.9 X
Track quality 99.9 %
Copy CRC A64B1E3D
Accurately ripped (confidence 2) [64AF3187] (AR v1)
Track 6
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\06 Track06.wav
Extraction speed 3.6 X
Copy CRC DFF6EE99
Accurately ripped (confidence 2) [48A967C9] (AR v1)
Track 7
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\07 Track07.wav
Peak level 71.6 %
Extraction speed 3.3 X
Copy CRC B835982F
Accurately ripped (confidence 2) [DBC7230C] (AR v1)
Track 8
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\08 Track08.wav
Extraction speed 3.5 X
Copy CRC 006364BA
Accurately ripped (confidence 2) [C8687B97] (AR v1)
Track 9
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\09 Track09.wav
Extraction speed 4.1 X
Copy CRC 78335704
Accurately ripped (confidence 2) [59E99A43] (AR v1)
Track 10
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\10 Track10.wav
Copy CRC 483A19EC
Accurately ripped (confidence 2) [76048E71] (AR v1)
Track 11
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\11 Track11.wav
Peak level 97.7 %
Extraction speed 4.4 X
Copy CRC D6F9374B
Accurately ripped (confidence 2) [7DBF5BEA] (AR v1)
Track 12
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\12 Track12.wav
Peak level 95.8 %
Copy CRC 70DB9AF6
Accurately ripped (confidence 2) [C2ED1DA8] (AR v1)
All tracks accurately ripped
log2
EAC extraction logfile from 8. August 2011, 12:36
Filename C:\Documents and Settings\Owner\Desktop\New Folder (2)\Taylan Ayık - yalnız hayal.wav
Extraction speed 3.8 X
Copy CRC CB492BD9
AccurateRip summary
Track 1 accurately ripped (confidence 2) [603A39A6] (AR v1)
Track 2 accurately ripped (confidence 2) [46CDEF59] (AR v1)
Track 3 accurately ripped (confidence 2) [73BFDDCE] (AR v1)
Track 4 accurately ripped (confidence 2) [24DAEF86] (AR v1)
Track 5 accurately ripped (confidence 2) [64AF3187] (AR v1)
Track 6 accurately ripped (confidence 2) [48A967C9] (AR v1)
Track 7 accurately ripped (confidence 2) [DBC7230C] (AR v1)
Track 8 accurately ripped (confidence 2) [C8687B97] (AR v1)
Track 9 accurately ripped (confidence 2) [59E99A43] (AR v1)
Track 10 accurately ripped (confidence 2) [76048E71] (AR v1)
Track 11 accurately ripped (confidence 2) [7DBF5BEA] (AR v1)
Track 12 accurately ripped (confidence 2) [C2ED1DA8] (AR v1)
Nice!!! :true:
Congratulations to a good start :thanx: :dance:
mirror (lossless) : MultiUp l Narod
PostPosted: 23 Jul 2012
Lоcаtion: Saint Petersburg
БОльшое спасибо за альбом и за зеркало отдельное спасибо Андрею!
PostPosted: 20 Aug 2012
Приятный альбом. Товарещ Тайлан голосом чем-то на Блеки Лоулеса местами похож.
Вообщем совсем не ожидал ничего подобного услышать, думал будет, как обычно, тупая харда место-кабацкого розлива, а тут всё очень грамотно и приятно для уха получилось.
Ещё раз спасибо за релиз!
