It is currently 31 Aug 2026
PostPosted: 18 Aug 2010
Lоcаtion: Пенза
Thunder Way -1993- The Order Executors (demo)
1. Nothing Else to Try 05:29
2. The Order Executors 06:10
3. The Last Warrior 04:10
4. Unexpected Sufferings 05:56
5. Dancing with Beasts 03:50
6. The Devil's Rule 07:40
7. Crimes With Prepensation 08:48
8. Victims of Confusion 05:30
9. Future Punishments 06:07
Лось взят на ММТ.Рип сделан roytheiron666
Log
EAC extraction logfile from 14. June 2010, 9:25
Thunder Way / The Order Executors
Used drive : PIONEER DVD-RW DVR-216D Adapter: 0 ID: 1
Read offset correction : 96
Selected bitrate : High Lossless Compression
Add ID3 tag : Yes
Command line compressor : C:\Program Files\Exact Audio Copy\MAC.EXE
1 | 0:00.00 | 5:28.60 | 0 | 24659
2 | 5:28.60 | 6:06.23 | 24660 | 52132
3 | 11:35.08 | 4:17.42 | 52133 | 71449
4 | 15:52.50 | 5:53.56 | 71450 | 97980
5 | 21:46.31 | 4:05.24 | 97981 | 116379
6 | 25:51.55 | 7:39.12 | 116380 | 150816
7 | 33:30.67 | 8:43.54 | 150817 | 190095
8 | 42:14.46 | 5:26.58 | 190096 | 214603
9 | 47:41.29 | 5:58.03 | 214604 | 241456
Filename F:\MUSIC\CD_IMAGE_34\COVERS OF WRITED CD\THUNDER WAY [1993] [TAPE] The Order Executors\Thunder Way - The Order Executors.wav
Copy CRC ED11F0D1
Cue
REM GENRE "Heavy Metal"
REM DATE 1993
REM DISCID 720C9309
PERFORMER "Thunder Way"
TITLE "The Order Executors"
FILE "Thunder Way - The Order Executors.ape" WAVE
TITLE "Nothing Else To Try"
INDEX 00 05:28:48
INDEX 01 05:28:60
TITLE "The Last Warrior"
INDEX 00 11:35:03
INDEX 01 11:35:08
TITLE "Unexpected Sufferings"
INDEX 01 15:52:50
TITLE "Dancing With Beasts"
INDEX 01 21:46:31
TITLE "The Devil's Rule"
INDEX 01 25:51:55
TITLE "Crimes With Prepensation"
INDEX 01 33:30:67
TITLE "Victims Of Confusion"
INDEX 01 42:14:46
TITLE "Future Punishments"
INDEX 01 47:41:29
Narod
Денис,БОЛЬШОЕ СПАСИБО!!! :thanx: :true: :true: :true:
PostPosted: 19 Aug 2010
:true: :true: :true: :thanx: :thanx: :thanx: :thanx: NICE!
[youtube]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/53cJ8UEfDxw?fs=1&amp;hl=ru_RU"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/53cJ8UEfDxw?fs=1&amp;hl=ru_RU" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
А так называемый селф-ремастер кто-то сравнивал с оригиналом?
Заливать его или нунафек? :vic:
PostPosted: 29 Aug 2010
THUNDER WAY [1993] [TAPE] [Self Remastered-2010] The Order Executors [EAC-APE] By RoYtheIroN666 [MeTaLMaDNess.TeaM].rar
MultiUp l Narod
EAC extraction logfile from 14. June 2010, 9:47
Thunder Way / The Order Executors (Remaster)
Add ID3 tag : Yes
1 | 0:00.00 | 5:24.47 | 0 | 24346
2 | 5:24.47 | 6:02.57 | 24347 | 51553
3 | 11:27.29 | 4:11.55 | 51554 | 70433
4 | 15:39.09 | 5:49.02 | 70434 | 96610
5 | 21:28.11 | 3:58.67 | 96611 | 114527
6 | 25:27.03 | 7:33.50 | 114528 | 148552
7 | 33:00.53 | 8:37.66 | 148553 | 187393
8 | 41:38.44 | 5:23.25 | 187394 | 211643
9 | 47:01.69 | 5:57.46 | 211644 | 238464
Filename F:\MUSIC\CD_IMAGE_34\COVERS OF WRITED CD\THUNDER WAY [1993] [TAPE] The Order Executors\Thunder Way - The Order Executors (Remaster).wav
Peak level 97.7 %
Range quality 99.9 %
Copy CRC E1738F51
REM DATE 1993
REM DISCID 790C6B09
TITLE "The Order Executors (Remaster)"
FILE "Thunder Way - The Order Executors (Remaster).ape" WAVE
INDEX 01 05:24:47
INDEX 01 11:27:29
INDEX 01 15:39:09
INDEX 01 21:28:11
INDEX 00 25:27:00
INDEX 01 25:27:03
INDEX 01 33:00:53
INDEX 01 41:38:44
INDEX 01 47:01:69
interesting! thankyou Scatterbrain :thanx:
Emil write to plz, if possible on both releases - where better quality?
I still do not listen ... :oops:
The one you posted! it was clearer and the volume was increased a bit. :true:
Also a lot of scans included to make a nice CD-R copy!
Well :true:
Thanx to RoYtheIroN666 :thanx:
PostPosted: 13 Sep 2010
Спасибо Денис и Андрюха, заберу обе версии :thanx:
PostPosted: 12 Oct 2011
Зарегился вот...
Lоcаtion: Greece
Just to let you know what was uploaded on metalmadness doesnt have the normal speed, RoyTheIron666 is a personal friend and its the guy who ripped this.
He understood that a mistake had happened when he had already uploaded it on metalmadness.
http://noisy-subculture.blogspot.com
ТрэшЭрос
Lоcаtion: Гулькевичи
...и немного видео 1993 года:
http://www.nme.com/nme-video/youtube/id ... h/executor :true:
После просмотра клипа число скачиваний резко пошло вверх :crazy:
Thrash no trash!!!
ТрэшЭрос
1-ая Народная ссыль того, :esel: ...
Thrash no trash!!!
Угу, только там рип кривой, насколько я понял. Так что :pardon:
ТрэшЭрос
Саныч, спасибо за не "Нунафек"! :thanx: :true: :true: :true:
Thrash no trash!!!
PostPosted: 22 Oct 2011
Вот это весчь!!! Спасибо за просвещение!
