It is currently 21 Feb 2026
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: 30 Aug 2011
Scavenger [1985] Battlefields (1994 reissue)
Mausoleum (704144.2)
Genre: heavy metal
Country: Belgium
Contents: flac/cue/log/covers
01. No Return
02. Devil's Answer
03. Ready
04. Battlefield
05. Rock Fever
06. Into The Fire
07. Vengeance
08. Heartbreaker
09. Free
10. My Ears Are Ringing
Playtime: 32:31
Lineup:
Jan Boeken - vocals
Marc Herremans - lead and acoustic guitars
Patrick Van Schooren - rhythm guitars
Roger Roscan - bass
Luc Ebinger - drums
Walter Christian Rothe - synthesizer programming
"The Scavettes" - backing vocals
EAC log
Exact Audio Copy V1.0 beta 1 from 15. November 2010
EAC extraction logfile from 18. May 2011, 15:05
Scavenger / Battlefields (1994)
Used drive  : Optiarc DVD RW AD-7240S   Adapter: 2  ID: 0
Defeat audio cache      : Yes
Read offset correction                      : 48
Used interface                              : Native Win32 interface for Win NT & 2000
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.00 |  3:51.30 |         0    |    17354
        2  |  3:51.30 |  3:17.65 |     17355    |    32194
        3  |  7:09.20 |  2:45.67 |     32195    |    44636
        4  |  9:55.12 |  2:52.35 |     44637    |    57571
        5  | 12:47.47 |  3:25.68 |     57572    |    73014
        6  | 16:13.40 |  3:48.45 |     73015    |    90159
        7  | 20:02.10 |  3:25.02 |     90160    |   105536
        8  | 23:27.12 |  3:27.13 |    105537    |   121074
        9  | 26:54.25 |  3:12.65 |    121075    |   135539
       10  | 30:07.15 |  2:24.10 |    135540    |   146349
     Filename D:\spiralarch\Scavenger - Battlefields (1994).wav
     Peak level 99.0 %
     Extraction speed 0.2 X
     Copy CRC 4B81511F
Track  1  not present in database
Track  2  not present in database
Track  3  not present in database
Track  4  not present in database
Track  5  not present in database
Track  6  not present in database
Track  7  not present in database
Track  8  not present in database
Track  9  not present in database
Track 10  not present in database
==== Log checksum 71373F419BDC38529D40092949E9297BA2EDA4854A101BF178753BEA6F7AE517 ====
Спасибо за диск Димке church :thanx: Сграбил еще осенью, но пока не слушал... придётся на ММТ выложить, чтобы послушать наконец :crazy:
Lоcаtion: Hell Is Here
Thank You Very Much ! :thanx: :true:
mirror: MultiUp l Narod
Lоcаtion: Serbia
:thanx: :thanx: :thanx:
Lоcаtion: BULGARIA
Thank you!!!!
Олег, залей пожалуйста картинку на форум... вложения больше такого не существует...
дык я на форум и залил :umnik:
Серёг, трезвеем - картинка видна и лежит (стоит?) на своём месте :crazy:
Old Time Rock`n`Roll
Lоcаtion: г.Ульяновск
:thanx: :true:
PostPosted: 31 Aug 2011
Серёг, трезвеем
Последний раз бухал 5 августа, а картинки нет!
Картиночным имг ты окружил этот урл download/file.php?id=2236 так? Тыркаем, читаем... :blum:
Спасибо, послушаем... :thanx:
а картинки нет!
:vic: я тоже не вижу.
Картинка на месте. Выбросьте ваши Оперы и Мазиллы подальше :fingal:
Олег взял его с форума, но из другого топика.
я вижу картинку по этой ссылке (IE8) :pardon:
(IE8
Google Chrome :pardon:
Это я вижу на странице...
А это, если перехожу по адресу картинки download/file.php?id=2236
Там же ясно написано ВЛОЖЕНИЯ НЕ СУЩЕСТВУЕТ :dash:
А браузер я менять не планирую... надо же что бы всем удобно было, правильно?
Lоcаtion: BULGARIA
ЕХ ,тая картинка ,важный важный........ оставляйте человека ,важна музика :true:
ТрэшЭрос
Lоcаtion: Гулькевичи
Thrash no trash!!!
О, кста пора объявление снять в шапке :shok:
Серёг, спасибо за скрин :thanx:
PostPosted: 01 Sep 2011
не надо, мозилла все отличн опоказывает :blum:
