It is currently 01 Jul 2025
Post new topic Reply to topic  [ 128 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: 31 Mar 2010
ыыыы
Lоcаtion: Пушкино, МО
Жанр: Heavy Metal
Происхождение исполнителя: Германия
Год издания: 1988
Год издания данного носителя: 1990
Страна-производитель носителя: Япония
Аудио кодек: FLAC
Тип рипа: image+.cue
Битрейт аудио: lossless
Продолжительность: 46:31
Рип: Собственный
Лейбл: NOISE/VICTOR
Каталоговый номер: VICP-8010
Матрица: VICP-8010-1-A1D 11 V (JVC)
Треклист:
1. Warp 7 04:29
2. Terrion 04:54
3. Locked Out 06:26
4. Across the Universe 03:52
5. R.M.U. 05:48
6. Grapes of Fear 03:57
7. Retaliation Positive 04:27
8. Killing Fields 04:24
9. Wizard Force 04:28
10. Galactos 03:46
"Куй"
REM GENRE "Heavy Metal"
REM DATE 1988
REM DISCID 8C0AE70A
PERFORMER "Scanner"
TITLE "Hypertrace [VICP-8010]"
FILE "Scanner - Hypertrace [VICP-8010].flac" WAVE
TITLE "Warp 7"
PERFORMER "Scanner"
INDEX 00 00:00:00
INDEX 01 00:00:37
TITLE "Terrion"
PERFORMER "Scanner"
INDEX 00 04:29:20
INDEX 01 04:29:67
TITLE "Locked Out"
PERFORMER "Scanner"
INDEX 00 09:22:11
INDEX 01 09:23:52
TITLE "Across the Universe"
PERFORMER "Scanner"
INDEX 00 15:48:23
INDEX 01 15:49:25
TITLE "R. M. U."
PERFORMER "Scanner"
INDEX 00 19:39:45
INDEX 01 19:41:62
TITLE "Grapes of Fear"
PERFORMER "Scanner"
INDEX 00 25:29:04
INDEX 01 25:29:72
TITLE "Retaliation Positive"
PERFORMER "Scanner"
INDEX 00 29:26:43
INDEX 01 29:26:60
TITLE "Killing Fields"
PERFORMER "Scanner"
INDEX 00 33:52:67
INDEX 01 33:53:57
TITLE "Wizard Force"
PERFORMER "Scanner"
INDEX 00 38:17:26
INDEX 01 38:17:37
TITLE "Galactos"
PERFORMER "Scanner"
INDEX 00 42:44:11
INDEX 01 42:45:52
"Лог"
EAC extraction logfile from 31. March 2010, 9:31
Scanner / Hypertrace [VICP-8010]
Used drive : ASUS DRW-2014S1T Adapter: 1 ID: 1
Read offset correction : 6
Selected bitrate : 128 kBit/s
Add ID3 tag : No
Additional command line options : -8 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T "comment=EAC 0.9beta4 / FLAC 1.1.0 q6" %s
1 | 0:00.37 | 4:29.30 | 37 | 20241
2 | 4:29.67 | 4:53.60 | 20242 | 42276
3 | 9:23.52 | 6:25.48 | 42277 | 71199
4 | 15:49.25 | 3:52.37 | 71200 | 88636
5 | 19:41.62 | 5:48.10 | 88637 | 114746
6 | 25:29.72 | 3:56.63 | 114747 | 132509
7 | 29:26.60 | 4:26.72 | 132510 | 152531
8 | 33:53.57 | 4:23.55 | 152532 | 172311
9 | 38:17.37 | 4:28.15 | 172312 | 192426
10 | 42:45.52 | 3:45.53 | 192427 | 209354
Filename Y:\Музыка\Scanner\1988 Hypertrace\Scanner - Hypertrace [VICP-8010].wav
Copy CRC 388C39E1
Состав:
Michael Knoblich: Vocals
Axel Julius: Guitar
Tom Sopha: Guitar
Martin Bork: Bass
Wolfgang Kolorz: Drums
Narod.Ru
Фото
PostPosted: 01 Feb 2016
Lоcаtion: Russia, Novosibirsk
А давай мы тебя ещё на сибилянтах ещё проверим?
Тута их нетути! :fingal:
Может у кого-то и есть :benya:
Дык вить, ясен пень у кого. :benya:
Действительно, зачем то полезли менять начало в Across The Universe. Иногда от ремастеринга есть прок, но такое бывает очень редко. То что слушает здесь основная масса, обычно изначально вполне сносно записано, а потому весь смысл изменений подрубить деньжат с любителей металла и сделать что-то полезное :esel: , например, бахнуть перегруз и погромче.
Серёг, если не в курсе, почитай wiki - Война громкости
В 99% случае лучше всего прописаны и соответственно лучше всего сохранившие энергетику были первопрессы :pardon: :oldman:
пс
Вначале слушал в наушниках Бауэрдинамик 880, не помню за сколько баксов, но лет пять назад они стоили около 20 тыров, слышно жуткие перегрузы прекрасно. На домашней акустике такая же картина, и даже на рабочем компе с простенькими китайскими Dialog (15 ваттные колонки с 25 ваттным сабом) всё замечательно слышно. Подобные ремастеры в корзину, а брать самое лучшее, например вариант от Димы iezuit, который он тут изначально выложил.
Тут вить вот какое дело, Дим:
- любое вмешательство в исходный сигнал приводит к его ухудшению, т.е. увеличение уровня до перегрузки приводит к сильному росту гармонических искажений (причём чётных гармоник, наиболее заметных для уха),
- изменения частотные (эквалайзинг эквалайзером) приводят к росту ещё и фазовых искажений, которые тоже ухо здорово ощущает.
- ошибочно считается (хотя технически это правильно), что увеличение уровня "громкости" расширяет динамический диапазон, что якобы приводит в увеличению глубины и объёма звука, маскируя изначальную плоскость звучания цидов. Но до определённого порога, который многие ремастёры не выдерживают, что приводит к обратному эффекту - компрессированию динамического диапазона.
- в результате мы имеем усреднённое звучание, обогащённое гармоническими и фазовыми искажениями, ограниченное клиппингом (и его производной - компандерным эффектом), что есть ни что иное, как сплошное дерьмо.
Но так щас модно, а вить благая же цель преследовалась - улучшить звучок цида. :pardon:
andytih wrote:
В фубар засадил япошку и ремастер - услышал в наушниках сразу :meloman:
Ббрр, и одновременно слушал? :starz:
А давай мы тебя ещё на сибилянтах ещё проверим? :kro:
Поочередно естессна, потрэково :meloman:
А где на сибилянты провериться? :fingal:
А, фуф, а то думал, авось догадался на двух аппаратах и четырех колонках запустить два диска :crazy:
Про сибилянты у нас Виталик начал. Примерно вот здесь: :arrow: viewtopic.php?p=228625#p228625
Затем пояснил, что это :arrow: viewtopic.php?p=185638#p185638 :arrow: viewtopic.php?p=250131#p250131
А затем пришёл Лёня и принес своих сибилянтов: :arrow: viewtopic.php?p=247908#p247908 :arrow: viewtopic.php?p=248014#p248014 :arrow: viewtopic.php?p=248189#p248189
Дальше есть живая ссылка на файлики с сибилянтами: :arrow: viewtopic.php?p=249460#p249460
- любое вмешательство в исходный сигнал приводит к его ухудшению, т.е. увеличение уровня до перегрузки приводит к (...)
Хорошо, хоть упомянул про перегрузы :kro: Ну и дальше текст мудрый :thanx:
Год назад точно бы чуть иначе написал =)
Хорошо, хоть упомянул про перегрузы Ну и дальше текст мудрый
С какого собсна? Год назад у мну та же самая научно-техническая база была, ниччо базово не изменилось, немного конкретных знаний тока добавилось после многочисленных экспериментов с саундом, да психоакустика стала поустойчивей. :pardon:
А чем тебе перегрузы-то понравились-то? :vic:
Не-не, сама формулировка мыслей иная. Почитай себя раннего, ты был более категоричен.
Вот перейдёшь через полтинник, и у тебю тож категоричности поубавиться. :benya: :pardon: ;)
Не Андрушко, обшибси! :vic:
Было так: один аппарат воспроизводящий - два аппарата усиливающих - 8 (восемь) колонок. :vic:
У меня её после "подросткового максимализма" стало как раз в меру :kro:
Ээмм, по две полосы на колонку? :lloo:
Хочешь подробностей? Получай:
- отдельный тракт стерео - два канала, 2 колонки.
- отдельный тракт Surround 5.1 - 5 каналов, 5 колонок + сабвуфер = 6 колонок.
- выходы у медиаплейера - стерео на усилок и HDMI на ресивер.
- можно включить всё одновременно, тогда зазвучат все 8 колонок.
- супер-аудио CD обычно имеет две звуковые дорожки - 2.0. и 5.1., вот они одновременно и звучат. :pardon: ;) :benya:
:thanx: Вот, теперь более чем ясно :dance:
PostPosted: 04 Feb 2016
Наконец послушал и японский вариант первопресса издания 1990 года, здесь добавлены две песни Wizard Force и Galactos. Наверное прикипел я к оригинальному варианту от Нойз, или песни для японцев были не самые лучшие, но по мне, самое то вариант от немцев 88 года. Хотя на discogs пишут, что альбом имеет концептуальный сюжет, но можно и не следить за историей, а по замыслу авторов порядок песен таков:
1. Grapes of Fear
2. Locked Out
3. Across the Universe
(4. Wizard Force)
5. Retaliation Positive
(6. Galactos)
7. Warp 7
8. Killing Fields
9. R.M.U.
10. Terrion
Может его так и на диск записать надо :starz: , но как минимум в порядке изначально придуманной авторами прослушать придётся, а потом...забыть про него ещё на 20 лет :crazy:
"R.M.U." расшифровывается как "ретикулярной модульный блок" и представляет собой устройство изображённое на обложке :begun:
1. Grapes of Fear
2. Locked Out
(4. Wizard Force)
(6. Galactos)
7. Warp 7
8. Killing Fields
9. R.M.U.
10. Terrion
Гыы, я когда-то, в начале 90x на кассету в таком порядке записывал (без Galactos), прочитав либретто :pardon:
Кстати, Wizard Force изначально была на оригинальном CD. А Galactos была записана чуть раньше альбома, для сборника Doomsday News. Так что не только для японцев ;)
Значит я начинал с пластиночного варианта: Image
A1 Warp 7 4:27
A2 Terrion 4:53
A3 Locked Out 6:23
A4 Across The Universe 3:52
B1 R.M.U. 5:46
B2 Grapes Of Fear 3:58
B3 Retaliation Positive 4:25
B4 Killing Fields 4:23
Круто, какие люди у нас на форуме продвинутые Image
andytih wrote:
прочитав либретто
Ваше бы, Андрей, умение, да в нужное русл0 :kro: viewtopic.php?f=12&t=11652
PostPosted: 05 Feb 2016
Lоcаtion: из Тулы
[quote="[url=http://80s.takemetal.com/viewtopic.php?p=253553#p253553] Galactos была записана чуть раньше альбома, для сборника Doomsday News. Так что не только для японцев ;)[/quote]
приобрел себе такой сборничег в виниловом формате, очень там много интересного и оригинального, я вам скажу...
КМА
А у нас же он есть. Вроде.
С Кинг-Кингом на морде?
