It is currently 20 Aug 2026
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: 07 Jan 2010
Всё внутри.
http://www.megaupload.com/?d=J1MWRFWD
Чтобы прожечь болванки, надо:
1. ФЛАКи перевести в ВАВы.
2. Для Battle Cry и The Curse прожигаем данными куями.
3. Для Warning Of Danger/Nightmares необходимо склеить ВАВы Warning Of Danger следуемый ВАВами Nightmares-ов в 1 ВАВ именуемый Range.wav. Порядок важен. Т.е. сначала Warning Of Danger потом Nightmares. Kyй прилагается и работает с единым ВАВом.
Omen - 1984 - Battle Cry [flacs]
Image Image Image
mirror: Narod l M-Cloud
EAC extraction logfile from 6. March 2010, 22:23
Omen / Battle Cry
Used drive : PLEXTOR DVDR PX-760A Adapter: 1 ID: 0
Make use of C2 pointers : Yes
Read offset correction : 30
1 | 0:00.00 | 3:29.33 | 0 | 15707
2 | 3:29.33 | 4:27.60 | 15708 | 35792
3 | 7:57.18 | 3:40.47 | 35793 | 52339
4 | 11:37.65 | 3:00.30 | 52340 | 65869
5 | 14:38.20 | 4:06.48 | 65870 | 84367
6 | 18:44.68 | 3:42.32 | 84368 | 101049
7 | 22:27.25 | 3:09.53 | 101050 | 115277
8 | 25:37.03 | 2:46.12 | 115278 | 127739
9 | 28:23.15 | 4:11.50 | 127740 | 146614
10 | 32:34.65 | 4:00.40 | 146615 | 164654
Filename N:\ToCD\Omen\Omen - Battle Cry.wav
Peak level 86.3 %
Copy CRC F92C0AA4
REM GENRE "Heavy Metal"
REM DATE 1984
REM DISCID 9108930A
PERFORMER "Omen"
TITLE "Battle Cry"
FILE "Omen - Battle Cry.wav" WAVE
TITLE "Death Rider"
PERFORMER "Omen"
TITLE "The Axeman"
PERFORMER "Omen"
INDEX 00 03:27:73
INDEX 01 03:29:33
TITLE "Last Rites"
PERFORMER "Omen"
INDEX 00 07:56:13
INDEX 01 07:57:18
TITLE "Dragon's Breath"
PERFORMER "Omen"
INDEX 01 11:37:65
TITLE "Be My Wench"
PERFORMER "Omen"
INDEX 00 14:37:20
INDEX 01 14:38:20
TITLE "Battle Cry"
PERFORMER "Omen"
INDEX 00 18:43:65
INDEX 01 18:44:68
TITLE "Die By The Blade"
PERFORMER "Omen"
INDEX 00 22:26:45
INDEX 01 22:27:25
TITLE "Prince Of Darkness"
PERFORMER "Omen"
INDEX 00 25:36:00
INDEX 01 25:37:03
TITLE "Bring Out The Beast"
PERFORMER "Omen"
INDEX 00 28:22:38
INDEX 01 28:23:15
TITLE "In The Arena"
PERFORMER "Omen"
INDEX 00 32:32:65
INDEX 01 32:34:65
PostPosted: 08 Jan 2010
Lоcаtion: Россия
А нельзя архивы разделить по-альбомно?
Вот здесь The Cures/Nightmares, переиздание 1996
http://ifolder.ru/15810356
http://ifolder.ru/15823914
http://ifolder.ru/15828152
http://ifolder.ru/15813470
http://ifolder.ru/15829873
Сканы здесь:
http://ifolder.ru/15894146
Спасибо. Качаю. А я свои уже залил. Но там внутри все поальбомно. Каждая директория = альбому.
PostPosted: 09 Jan 2010
Спасибище!! :true:
PostPosted: 11 Jan 2010
Мне звук на изданиях от 1996-ого года нравится больше, чем на первопрессах. Есть Warning Of Danger от 1996-ого года? И еще, если можно сканы. Спасибо.
PostPosted: 12 Jan 2010
Может быть будет, но скорее всего нескоро.Если появится, выложу.
Lоcаtion: Россия
На переиздании звук погромче. Ссылку на сканы добавил.
Погромче - это не важно. Но позвонче - это точно. За сканы :thanx: .
PostPosted: 10 Feb 2010
Лень, всё ещё нужно? Появился диск, правда поюзаный.
Кстати думал, что переиздание этого альбома от 1996 года тоже идёт с EP Nightmares.Оказалось, что нет.Только переиздание 1989 года...
1996? Ага. Нужно. :thanx: Warning Of Danger 1996 без Кошмаров идет.
Хорошо, сделаю в ближайшее время!
PostPosted: 17 Feb 2010
Лось здесь viewtopic.php?f=188&t=7513
PostPosted: 10 Jan 2011
Т.е., 89 год это тоже переиздание, а не первое издание на ЦД?
metallpaparazzy
Lоcаtion: Днепропетровск
rats wrote:
либо фолдырь тупит, либо я ниче не понимаю... все удалены :shok:
Да конечно, всё давно удалено :pardon:
Никто ж не хотит продлевать ссылки, а лить на Мегу, Народ (и продлевать файло раз в 45!! дней) или Мультик не привыкли.
По идее, этот альбом на Рутракере ну просто обязан быть.
С первопрессами точно не помню, я вроде качал, но нужно искать куда именно :fingal:
metallpaparazzy
rats wrote:
Последний раз редактировалось rats 12 янв 2010, всего редактировалось 3 раз(а).
Я ГОД перепутал... да и число... :dash: подумал -- дык, свежак же, ( тема вся помечена, как непрочитаная) на днях заливал, и уже удален. еще подумал: о, :oops: Леонид появился...
стареем :nunu:
Хы, я тож сначала глянул - думал запор начался... :oops:
PostPosted: 13 Jan 2011
Я ошибся, в 85 альбом только на виниле выходил, а первое издание на сиди как раз в 89, вместе с ипишкой вышло.
PostPosted: 04 Feb 2011
Бывает. Вобщем-то, это не принципиально - просто я удивился, что не слышал про более ранние издания.
