It is currently 26 Apr 2024
PostPosted: 08 Apr 2014
Lоcаtion: Spain
Super proyecto de banda de Ron Asheton y Dennis Thompson de The Stooges y MC5, que no llegó a nada y solo grabaron dos demos:
La primera es puro rock asesino de Detroit con un cantante que me recuerda a Bon Scott y la segunda suena a Heavy Rock en plan UFO o algo así, y a mi juicio menos interesante y estimulante.
Band: The New Order
Album: Declaration of War
Year: 1987
Country: U.S.A.
Genre: Detroit Killer Rock
Format: CDRip (FLAC + CUE + LOG + Covers)
Length: 32:25 min
Release: Tuco Pacífico[EsparaelMetal]
Demo 1975:
Lucky Strike
Declaration Of War
Hollywood Holidays
Sidewinder
Demo 1976:
I Can't Quit Ya
Rock 'N' Roll Soldiers
Of Another World
1975
Скачать:
MEGA
LOG
Code:
EAC extraction logfile from 8. April 2014, 8:38
The New Order / Declaration of War
Used drive  : TSSTcorpCDDVDW SE-S084F   Adapter: 2  ID: 0
Read mode               : Secure
Defeat audio cache      : Yes
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                    : Native Win32 interface for Win NT & 2000
Sample format      : 44.100 Hz; 16 Bit; Stereo
       Track |   Start  |  Length  | Start sector | End sector
          1  |  0:00.33 |  3:56.65 |        33    |    17797
          2  |  3:57.23 |  2:51.40 |     17798    |    30662
          3  |  6:48.63 |  3:58.02 |     30663    |    48514
          4  | 10:46.65 |  3:16.70 |     48515    |    63284
          5  | 14:03.60 |  3:05.45 |     63285    |    77204
          6  | 17:09.30 |  4:04.73 |     77205    |    95577
          7  | 21:14.28 |  4:49.05 |     95578    |   117257
          8  | 26:03.33 |  6:22.02 |    117258    |   145909
       Filename D:\Tuco Pacífico for EPM\The New Order\The New Order - Declaration of War.wav
       Extraction speed 1.6 X
       Test CRC 0D938C8F
       Copy CRC 0D938C8F
AccurateRip summary
Track  1  not present in database
Track  2  not present in database
Track  3  not present in database
Track  4  not present in database
Track  5  not present in database
Track  6  not present in database
Track  7  not present in database
Track  8  not present in database
---- CUETools DB Plugin V2.1.3
[CTDB TOCID: z5UgPryUZnNjK7KuEIanFgw9O7A-] disk not present in database, Submit result: discs with pregaps not supported in this protocol version
==== Log checksum D9281C37A3CA12A5B21A78A348096107EAE44EA050C4E1F92FB09CD86F2A851D ====
:shok: чувак с ножиком похож на один хулиганский персонаж из культового "Заводного апельсина" :true:
качнем, послушаем :thanx:
:crazy: Post-Punk :pardon:
Thnax Tuco :thanx:
mirror: Narod l M-Cloud
И всё же хард-рок здесь есть :oops:
PostPosted: 09 Apr 2014
Зарегился вот...
Lоcаtion: Isezu
прото-панк/хард-рок это, были активны в период 1975-1976 весь материал тогда и записан был а изданно все только в конце 80-х, тут Рон Эштон (на фото) и прочии ребятки засвечены причастные к становлению панк-рока!)
