It is currently 10 Aug 2026
PostPosted: 30 May 2010
Группа: Magnitude 9
Альбом: Decoding the Soul
Год: 2004
Лейбл: InsideOut
Стиль: Prog. Metal
Страна: USA
Формат: APE / Log / Cue / Covers
Line Up:
Corey Brown – Lead Vocals
Rob Johnson – Guitars
Joseph Anastacio Glean – Keyboards
Ian Ringler – Bass
John Homan - Drums
Tracks:
01. New Dimension (4:30)
02. Lies Within The Truth (6:00)
03. Facing The Unknown (5:14)
04. To Find A Reason (5:26)
05. Walk Through The Fire (4:48)
06. Dead In Their Tracks (4:03)
07. Changes (5:19)
08. Torn (3:30)
09. Thirty Days Of Night (3:33)
10. Sands Of Time (3:31)
LOG
EAC extraction logfile from 2. May 2009, 14:45
Magnitude Nine / Decoding The Soul
Used drive : TEAC CD-W516EB Adapter: 0 ID: 0
Read offset correction : 685
Gap handling : Not detected, thus appended to previous track
Add ID3 tag : Yes
Command line compressor : C:\Program Files\Flac\flac.exe
Additional command line options : -6 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
Use compression offset : 6
1 | 0:00.00 | 4:29.53 | 0 | 20227
2 | 4:29.53 | 6:00.15 | 20228 | 47242
3 | 10:29.68 | 5:13.53 | 47243 | 70770
4 | 15:43.46 | 5:26.11 | 70771 | 95231
5 | 21:09.57 | 4:48.15 | 95232 | 116846
6 | 25:57.72 | 4:02.44 | 116847 | 135040
7 | 30:00.41 | 5:19.28 | 135041 | 158993
8 | 35:19.69 | 3:29.67 | 158994 | 174735
9 | 38:49.61 | 3:33.07 | 174736 | 190717
10 | 42:22.68 | 3:30.63 | 190718 | 206530
Track 1
Filename N:\EAC\sole-survivor\Magnitude 9\01-New Dimension.wav
Peak level 99.0 %
Track quality 100.0 %
Copy CRC AFF13BD6
Cannot be verified as accurate (confidence 8) [2B3BDE6F], AccurateRip returned [C45CBF97]
Track 2
Filename N:\EAC\sole-survivor\Magnitude 9\02-Lies Within The Truth.wav
Peak level 99.0 %
Copy CRC 667B1F33
Cannot be verified as accurate (confidence 8) [70123A6D], AccurateRip returned [CEBC0E65]
Track 3
Filename N:\EAC\sole-survivor\Magnitude 9\03-Facing The Unknown.wav
Peak level 99.0 %
Copy CRC 73A3309F
Cannot be verified as accurate (confidence 8) [237B173C], AccurateRip returned [FFB0201C]
Track 4
Filename N:\EAC\sole-survivor\Magnitude 9\04-To Find A Reason.wav
Peak level 99.0 %
Copy CRC 20290CDE
Cannot be verified as accurate (confidence 8) [EE03BED7], AccurateRip returned [A830CE9F]
Track 5
Filename N:\EAC\sole-survivor\Magnitude 9\05-Walk Through The Fire.wav
Peak level 99.0 %
Track quality 99.9 %
Copy CRC 1328F9BF
Cannot be verified as accurate (confidence 8) [D804EEF8], AccurateRip returned [C0036C40]
Track 6
Filename N:\EAC\sole-survivor\Magnitude 9\06-Dead In Their Tracks.wav
Peak level 99.0 %
Copy CRC 3F36953F
Cannot be verified as accurate (confidence 8) [3CB90251], AccurateRip returned [3298CB61]
Track 7
Filename N:\EAC\sole-survivor\Magnitude 9\07-Changes.wav
Peak level 99.0 %
Copy CRC 482BD1D0
Cannot be verified as accurate (confidence 8) [83E9E3E8], AccurateRip returned [BC433130]
Track 8
Filename N:\EAC\sole-survivor\Magnitude 9\08-Torn.wav
Peak level 99.0 %
Copy CRC 9430A34C
Cannot be verified as accurate (confidence 7) [63BA95E4], AccurateRip returned [84A9461C]
Track 9
Filename N:\EAC\sole-survivor\Magnitude 9\09-Thirty Days Of Night.wav
Peak level 99.0 %
Copy CRC 74EE22AD
Cannot be verified as accurate (confidence 7) [663CCE00], AccurateRip returned [4FCB0A80]
Track 10
Filename N:\EAC\sole-survivor\Magnitude 9\10-Sands Of Time.wav
Peak level 98.9 %
Copy CRC 020EAA3C
Cannot be verified as accurate (confidence 7) [79926C15], AccurateRip returned [BED827A5]
[youtube]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/X6FHjRhRt8o&hl=ru_RU&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/X6FHjRhRt8o&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/youtube]
===================================DOWNLOAD========================================
Ifolder.ru
Megaupload
Narod.ru
