It is currently 20 Aug 2026
PostPosted: 16 Mar 2009
Lоcаtion: СПб
Morbid Scream - The Signal to Attack: 1986-1990 [FLAC]
Compilation
Genre: Thrash Metal
Origin: USA
Tracks 1 & 2: From Demo I (1987)
Tracks 3 - 6: From Demo II (1988)
Track 7: Unreleased Studio Track
Tracks 8 - 12: Live 11/11/87
Tracks 13 - 15: Live 6/3/88
Tracks 16 - 19: Live 10/28/88
1. The Coming Of War
2. Face Of Death
3. Morbid Scream
4. Timeless Sleep
5. Fist In Your Face
6. Cries Of Sanity
7. Tragic Memories
8. Into Oblivion (Live)
9. Pray For The End (Live)
10. State Of Shock (Live)
11. March Of The Undead (Live)
12. When The Killing Begins (Live)
13. The Coming Of War (Live)
14. To The Gallows (Live)
15. Fist In Your Face (Live)
16. Face Of Death (Live)
17. Timeless Sleep (Live)
18. Tragic Memories (Live)
19. Morbid Scream (Live)
Рип потрековый, т.е. каждая песня - отдельный файл.
http://ifolder.ru/11081838
http://ifolder.ru/11081839
http://ifolder.ru/11081840
http://ifolder.ru/11081841
Автор рипа неизвестен, ибо на том ресурсе откуда я качал, видимо, не принято его указывать :pardon:
EAC extraction logfile from 10. December 2008, 22:06
Morbid Scream / 1986-1990 - The Signal To Attack
Used drive : HP DVD Writer 1070r Adapter: 0 ID: 1
Defeat audio cache : No
Make use of C2 pointers : Yes
Read offset correction : 6
Gap handling : Appended to previous track
1 | 0:00.00 | 5:28.00 | 0 | 24599
2 | 5:28.00 | 2:57.29 | 24600 | 37903
3 | 8:25.29 | 2:44.57 | 37904 | 50260
4 | 11:10.11 | 3:13.22 | 50261 | 64757
5 | 14:23.33 | 2:25.40 | 64758 | 75672
6 | 16:48.73 | 3:39.17 | 75673 | 92114
7 | 20:28.15 | 3:01.74 | 92115 | 105763
8 | 23:30.14 | 3:40.62 | 105764 | 122325
9 | 27:11.01 | 3:13.63 | 122326 | 136863
10 | 30:24.64 | 3:35.56 | 136864 | 153044
11 | 34:00.45 | 4:39.07 | 153045 | 173976
12 | 38:39.52 | 3:04.21 | 173977 | 187797
13 | 41:43.73 | 5:02.18 | 187798 | 210465
14 | 46:46.16 | 3:06.20 | 210466 | 224435
15 | 49:52.36 | 2:22.37 | 224436 | 235122
16 | 52:14.73 | 2:55.22 | 235123 | 248269
17 | 55:10.20 | 2:56.37 | 248270 | 261506
18 | 58:06.57 | 2:53.49 | 261507 | 274530
19 | 61:00.31 | 2:40.36 | 274531 | 286566
Track 1
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 01 - The Coming Of War.wav
Pre-gap length 0:00:02.00
Track quality 100.0 %
Test CRC A9CD85EA
Copy CRC A9CD85EA
Track not present in AccurateRip database
Track 2
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 02 - Face Of Death.wav
Pre-gap length 0:00:02.03
Test CRC B6EE541B
Copy CRC B6EE541B
Track 3
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 03 - Morbid Scream.wav
Pre-gap length 0:00:02.04
Test CRC B2518DA2
Copy CRC B2518DA2
Track 4
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 04 - Timeless Sleep.wav
Test CRC E069F038
Copy CRC E069F038
Track 5
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 05 - Fist In Your Face.wav
Peak level 98.9 %
Test CRC A3BF26E9
Copy CRC A3BF26E9
Track 6
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 06 - Cries Of Sanity.wav
Peak level 99.7 %
Test CRC 8000EA71
Copy CRC 8000EA71
Track 7
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 07 - Tragic Memories.wav
Track quality 99.8 %
Test CRC 35A8DD65
Copy CRC 35A8DD65
Track 8
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 08 - Into Oblivion (Live).wav
Peak level 88.1 %
Test CRC 64C3374F
Copy CRC 64C3374F
Track 9
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 09 - Pray For The End (Live).wav
Pre-gap length 0:00:02.28
Peak level 83.7 %
Test CRC 16690AAD
Copy CRC 16690AAD
Track 10
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 10 - State Of Shock (Live).wav
Pre-gap length 0:00:02.22
Peak level 82.8 %
Test CRC 8D9CD572
Copy CRC 8D9CD572
Track 11
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 11 - March Of The Undead (Live).wav
Pre-gap length 0:00:02.13
Peak level 89.3 %
Test CRC CBC492A0
Copy CRC CBC492A0
Track 12
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 12 - When The Killing Begins (Live).wav
Pre-gap length 0:00:02.14
Peak level 90.4 %
Test CRC 13C939E5
Copy CRC 13C939E5
Track 13
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 13 - The Coming Of War (Live).wav
Peak level 90.1 %
Test CRC 40144DE1
Copy CRC 40144DE1
Track 14
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 14 - To The Gallows (Live).wav
Pre-gap length 0:00:02.25
Peak level 81.7 %
Test CRC 9CB8CA0F
Copy CRC 9CB8CA0F
Track 15
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 15 - Fist In Your Face (Live).wav
Pre-gap length 0:00:02.15
Peak level 81.4 %
Test CRC 4B766E80
Copy CRC 4B766E80
Track 16
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 16 - Face Of Death (Live).wav
Peak level 99.7 %
Test CRC 7CAB40AC
Copy CRC 7CAB40AC
Track 17
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 17 - Timeless Sleep (Live).wav
Peak level 99.7 %
Test CRC C8A86662
Copy CRC C8A86662
Track 18
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 18 - Tragic Memories (Live).wav
Peak level 99.7 %
Test CRC 2B5E8C87
Copy CRC 2B5E8C87
Track 19
Filename C:\Documents and Settings\Rob\Desktop\EAC Files\Morbid Scream - 1986-1990 - The Signal To Attack - 19 - Morbid Scream (Live).wav
Peak level 99.7 %
Test CRC 1E257E2B
Copy CRC 1E257E2B
Hunting, seeking, finding, destroying - die.
Praying, pleading, cannot wait - for death.
© Coroner
PostPosted: 17 Mar 2009
Роб автор. Ммм... рип потрековый :oops:
nomercy2all, спасибо :true:
Lоcаtion: СПб
Роб автор.
Это ты знал или как-то вычислил? :oops:
© Coroner
В лог посмотрел :al:
PostPosted: 22 Mar 2009
udo
Уважаемый nomercy2all
если не сложно в след раз указывай ссылки по порядку - а то я елки палки 3 и 4 части три скачал
Lоcаtion: SPb
Автор рипа Biomech. Я качал с первоисточника, а потом уже ты с меня.
Thrash & Death Metal releaser
Lоcаtion: СПб
odu, да, прошу прощения. Напутал слегка.
imaevil, с тебя это откуда?
© Coroner
я так полагаю, что с headbangers.nnm.ru, где его Макс (imaevil) выкладывал - я сам оттуда качал :roll:
док хэдбэнгерз, кстати, числится в друзьях у этого форума, ссылка на главной есть :true:
Lоcаtion: SPb
nomercy2all
Если б ты качал не с меня, то у тебя был бы NFO-файл, в котором указан и автор рипа, и др. информация. У меня он есть, но я его не клал в архив, т.к. у нас это не является обязательным условием. Правда, последнее время стали уже писать, что релиз, к примеру, MMT или торрентс.ру.
Lоcаtion: СПб
Я подключен к headbangers, но качал не оттуда. Более того, прежде чем сюда запостить, искал именно на хэдбэнгерс этот альбом, но видимо проглядел :pardon: Если бы там нашел, то и сюда бы не стал постить.
© Coroner
PostPosted: 23 Mar 2009
Lоcаtion: SPb
Да все в порядке. Значит ты скачал с другого источника, я знаю несколько мест где выкладывают релизы с headbangers. У меня к тебе никаких претензий нет по этому поводу. *DRINK*
PostPosted: 07 Jul 2009
сейчас как раз слушаю эту сборку. и кагбе немного прифигел, когда фронтмен обьявил песню "March Of The Undead" как "Марш Смерти" :shok:
полез даже специально на архивы с целью уточнить национальность команды. неа, все чистокровные техасские ковбойцы :vic:
