It is currently 25 Aug 2026
PostPosted: 20 Jun 2009
Liege Lord - 1985 - Freedom's Rise (reissued 2000)
Genre: Speed Power Heavy
Locaion: USA
Format: flac (tracks)+cue+log+covers
Line-up:
Vocals: Andy Michaud
Guitar: Pete McCarthy
Guitar: Tony Truglio
Bass: Matt Vinci
Drums: Frank Cortese
    1. Prodigy - 01:04
    2. Wielding Iron Fists - 03:15
    3. Dark Tale - 03:36
    4. Amnesty - 03:30
    5. Rage of Angels - 04:16
    6. Vials of Wrath - 04:46
    7. Warriors Farewell - 04:08
    8. For the King - 04:28
    9. Legionnaire - 03:54
    TPT: 32:58
Narod
Mega
Released by Soylent Green
EAC extraction logfile from 4. July 2007, 0:24 for CD
Liege Lord / Freedom's Rise (2000 Reissue)
Used drive : BENQ DVD DD DW1620 Adapter: 1 ID: 0
Read mode : Secure with NO C2, accurate stream, NO disable cache
Read offset correction : 618
44.100 Hz; 16 Bit; Stereo
Other options :
Track 1
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 01 - Prodigy.wav
Track quality 100.0 %
Test CRC 23A1C7EA
Copy CRC 23A1C7EA
Track 2
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 02 - Wielding Iron Fists.wav
Test CRC EDDEF070
Copy CRC EDDEF070
Track 3
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 03 - Darktale.wav
Test CRC A4F85122
Copy CRC A4F85122
Track 4
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 04 - Amnesty.wav
Track quality 99.9 %
Test CRC 7CA58CA2
Copy CRC 7CA58CA2
Track 5
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 05 - Rage Of Angels.wav
Test CRC 836E5413
Copy CRC 836E5413
Track 6
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 06 - Vials Of Wrath.wav
Test CRC E11ECD52
Copy CRC E11ECD52
Track 7
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 07 - Warrior's Farewell.wav
Test CRC 2A0E032F
Copy CRC 2A0E032F
Track 8
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 08 - For The King.wav
Test CRC A0880953
Copy CRC A0880953
Track 9
Filename C:\Documents and Settings\Soylent Green\Desktop\New Folder\EAC Files\Liege Lord - Freedom's Rise (2000 Reissue) - 09 - Legionnaire.wav
Test CRC D146CC55
Copy CRC D146CC55
No errors occured
spectrum
PostPosted: 25 Jun 2009
Спасиб спасиб спасиб!!!!! :true:
низкий поклон, муза жирная!!! :meloman:
We're pain, we're steel, a plot of knives, we're Transmaniacon MC.
Андрюш, будь ласка, если не в напряг, запости сканы отдельно. Качнул с лоси.мул, а там архив без сканов вообще. Там, кстати, и два других. :true:
Sergey wrote:
сканы отдельно
Ну сканами это назвать сложно, всего два каверочка, передний вон уже есть, а второй щас залью...
Кстати, рип здесь потрэковый :pardon:
Да, ты ж написал выше. У меня такой же. За бумаги спасибо, выручил. А то уж вообще лыска. Только в папке с мп3 маленький фронтик.
:thanx: :true:
PostPosted: 14 Jul 2009
Lоcаtion: Hell Is Here
Thank You Very Much !! :thanx:
PostPosted: 15 Jul 2009
o! Вот этого лося группы как раз не хватало! :thanx:
PostPosted: 21 Oct 2014
Это Old Metal Records? Ищу Black Dragon. Помогите.
Угу.
:vic: А у нас тута точно нету? :vic:
PostPosted: 01 Apr 2018
http://dropmefiles.com/PdIL6
Оригинальное издание от Black Dragon 1985 года.Альбом (как и почти все альбомы выпускаимые этим лэйблом) как то не очень.Все таки самый лучший это альбом 1988 года(который и Андрейки понравился).Ссылка действует 14 дней! :true:
PostPosted: 02 Apr 2018
PostPosted: 05 Jun 2018
Liege Lord - 1985 - Freedom's Rise (1996 FR Black Dragon Records BDCD 004) [flac]
mirror: Giga l Drop l Narod l M-Cloud
Не понял я этот альбом.
Группа тоже помню плохо по 80-м, (название примелькалось, ясное дело, давно, но саму музыку не очень помню) казалось мне наивному, что нарезали они скоростной US Power (типа Savatage/Metal Church с примерно таким же великолепным вокалистом), или что в этом духе, потому слушал с особым интересом - освежить свою память и в тоже время проверить чуйку и.. желание услышать то, чего ожидал.
А вот и не вышло.
Как не гонял альбом утром, ночью веером и днём, всё равно он мне так и не зашёл :(
Музыка хоть местами и скоростная попадается, но явно это всё дело можно назвать Epic Heavy с элементами Power, но вот даже несмотря на то, что сама музыка не выглядит (на слух) устаревшей, но веет от неё какой-то ненастоящей мрачностью и сказками недоделанными.
"Илья Муромец после 33-го года всё же нашёл коня".
Явно нужно для этого понимать полностью лирику песен, интонации и вообще - слушать альбом в то время, когда подобная музыка была модной, что-ли..
Или, как ещё один из вариантов - быть Лёней.
Увы, все три варианта для меня пока пролетели как фанера шведская над Полтавой и её двумя нонешними футбольными командами в УПЛ :vic:
7/10
Оценка чисто поставлена под влиянием (давлением) времени и шоб не побили местные гурманы подобной скучной музыки :crazy:
EAC extraction logfile from 13. January 2015, 22:56
Used drive : PIONEER DVD-RW DVR-221L Adapter: 2 ID: 0
1 | 0:00.00 | 1:04.40 | 0 | 4839
2 | 1:04.40 | 3:12.50 | 4840 | 19289
3 | 4:17.15 | 3:36.30 | 19290 | 35519
4 | 7:53.45 | 3:27.35 | 35520 | 51079
5 | 11:21.05 | 4:19.30 | 51080 | 70534
6 | 15:40.35 | 4:43.10 | 70535 | 91769
7 | 20:23.45 | 4:08.70 | 91770 | 110439
8 | 24:32.40 | 4:28.10 | 110440 | 130549
9 | 29:00.50 | 4:01.05 | 130550 | 148629
Filename D:\Свои Рипы на Линия Жизни\Liege Lord - Freedom's Rise.wav
Extraction speed 6.8 X
Range quality 99.9 %
Copy CRC 705AD83D
REM GENRE Metal
REM DATE 1985
REM DISCID 7607BD09
PERFORMER "Liege Lord"
TITLE "Freedom's Rise"
FILE "Liege Lord - Freedom's Rise.flac" WAVE
TITLE "Prodigy"
FLAGS DCP
TITLE "Wielding Iron Fists"
FLAGS DCP
INDEX 01 01:04:40
TITLE "Darktale"
FLAGS DCP
INDEX 01 04:17:15
TITLE "Amnesty"
FLAGS DCP
INDEX 01 07:53:45
TITLE "Rage Of Angels"
FLAGS DCP
INDEX 01 11:21:05
TITLE "Vials Of Wrath"
FLAGS DCP
INDEX 01 15:40:35
TITLE "Warriors Farewell"
FLAGS DCP
INDEX 01 20:23:45
TITLE "For The King"
FLAGS DCP
INDEX 01 24:32:40
TITLE "Legionnaire"
FLAGS DCP
INDEX 01 29:00:50
О, Серёг, надеюсь, твои слова и музыка группы до меня дойдут =) :kro:
бей его!!!!
PostPosted: 08 Jun 2018
Это пиратка, такая же как здесь.
Рипы сделаны разными людьми но ВАВы идентичны. Проверено ЕАСом.
Получается, что мы сами у себя и украли рип? :kro:
Логи разные, конечные результаты - идентичные.
