Killers - 1985 - Fils De La Haine (reissued In 2008)Band: Killers
Album: Fils De La Haine
Label: ?
Genre: Speed Metal
Country: France
Format: Flac + Log + Cue + Covers
Tracklist:1. Le fils de la haine 03:45
2. Sacrifice 03:00
3. Rosalind 05:40
4. Pense à ton suicide 03:40
5. Au nom du rock'n'roll 03:25
6. Killers 04:50
7. Mercenaire 02:20
8. Le magicien d'Oz 04:50
9. Heavy metal 04:00
10. Chevaliers du déshonneur 03:30
11. Ahachtachta Chtilabeh!!! 00:25
LOG
EAC extraction logfile from 9. April 2011, 16:34
Killers / ...Fils De La Haine
Used drive : PIONEER DVD-RW DVR-116D Adapter: 0 ID: 0
Read offset correction : 96
Selected bitrate : 32 kBit/s
Add ID3 tag : No
1 | 0:00.00 | 3:43.48 | 0 | 16772
2 | 3:43.48 | 3:02.57 | 16773 | 30479
3 | 6:46.30 | 5:36.38 | 30480 | 55717
4 | 12:22.68 | 3:37.44 | 55718 | 72036
5 | 16:00.37 | 3:23.17 | 72037 | 87278
6 | 19:23.54 | 4:47.19 | 87279 | 108822
7 | 24:10.73 | 2:19.69 | 108823 | 119316
8 | 26:30.67 | 4:50.59 | 119317 | 141125
9 | 31:21.51 | 4:00.60 | 141126 | 159185
10 | 35:22.36 | 3:28.15 | 159186 | 174800
11 | 38:50.51 | 0:22.00 | 174801 | 176450
Filename D:\Музыка\Lossless\Killers - ... Fils De La Haine (1985)\Killers - ...Fils De La Haine.wav
Peak level 98.8 %
Range quality 99.9 %
Copy CRC 3248C9EA
Track 1 cannot be verified as accurate (confidence 2) [011A661E], AccurateRip returned [73E31BEC]
Track 2 cannot be verified as accurate (confidence 2) [E94D9359], AccurateRip returned [69EA2D61]
Track 3 cannot be verified as accurate (confidence 2) [839BEF22], AccurateRip returned [67BD56FC]
Track 4 cannot be verified as accurate (confidence 2) [3412FBAC], AccurateRip returned [1B89F927]
Track 5 cannot be verified as accurate (confidence 2) [A856CD32], AccurateRip returned [5E81822E]
Track 6 cannot be verified as accurate (confidence 2) [5ECFA25E], AccurateRip returned [97B4FCB7]
Track 7 cannot be verified as accurate (confidence 2) [70AE102E], AccurateRip returned [B92A3EBE]
Track 8 cannot be verified as accurate (confidence 2) [6CBDE3A3], AccurateRip returned [C3DEF425]
Track 9 cannot be verified as accurate (confidence 2) [74D84BEC], AccurateRip returned [FF072A07]
Track 10 cannot be verified as accurate (confidence 2) [C4FFD919], AccurateRip returned [B92C8530]
Track 11 cannot be verified as accurate (confidence 2) [966ABD5B], AccurateRip returned [9D9B9F85]
CUE
REM GENRE "Speed Metal"
REM DATE 1985
REM DISCID 8809300B
PERFORMER "Killers"
TITLE "...Fils De La Haine"
FILE "Killers - ...Fils De La Haine.flac" WAVE
TITLE "Le Fils De La Haine"
PERFORMER "Killers"
FLAGS DCP
TITLE "Sacrifice"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 03:41:48
INDEX 01 03:43:48
TITLE "Rosalind"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 06:44:30
INDEX 01 06:46:30
TITLE "Pense A Ton Suicide"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 12:20:68
INDEX 01 12:22:68
TITLE "Au Nom Du Rock 'N' Roll"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 15:58:37
INDEX 01 16:00:37
TITLE "Killers"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 19:21:54
INDEX 01 19:23:54
TITLE "Mercenaire"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 24:08:73
INDEX 01 24:10:73
TITLE "Le Magicien d'Oz"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 26:28:67
INDEX 01 26:30:67
TITLE "Heavy Metal"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 31:19:51
INDEX 01 31:21:51
TITLE "Chevaliers Du Deshonneur"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 35:20:36
INDEX 01 35:22:36
TRACK 11 AUDIO
TITLE "Ahachtachta Chtilabeh !!!"
PERFORMER "Killers"
FLAGS DCP
INDEX 00 38:48:51
INDEX 01 38:50:51
Spectrum
Narod.RuЭто по ходу дела переиздание, которое делала сама группа, поскольку опознавательных знаков какого-либо лейбла я не нашёл, но брал с официалки.
