It is currently 05 Mar 2026
PostPosted: 07 Jan 2011
Lоcаtion: Таллин, Эстония.
Forbidden - Forbidden Evil 1988 [WV] [1st Press] [Combat]
Band / Название Группы: Forbidden
Album title / Название Альбома : Forbidden Evil
Year / Год Выпуска : 1988
Genre / Жанр: Thrash Metal
Country / Страна : USA
Track list / Список Песен
01. 04:33 Chalice Of Blood
02. 04:19 Off The Edge
03. 06:26 Through Eyes Of Glass
04. 05:44 Forbidden Evil
05. 05:09 March Into Fire
06. 05:15 Feel No Pain
07. 04:17 As Good As Dead
08. 07:02 Follow Me
Technical info / Технические данные .
Source / Источник : CD
Format / Формат : WavPack, Lossless Very High Compression.
Resolution / Разрешение : 44 KHz / 16 Bit
Total playing time / Суммарное время проигрывания : 42:46
Album art / Полиграфия: Booklet, back cover, CD.
Буклет, задняя обложка, диск.
Comment / Комментарий
Ripped from the first press CD which was released under Combat.
Рип сделан с первого издания, выпущенного под Combat.
"EAC Log"
EAC extraction logfile from 5. January 2011, 18:28
Forbidden / Forbidden Evil
Used drive : ASUS DRW-1814BLT Adapter: 3 ID: 0
Read offset correction : 6
1 | 0:00.47 | 4:33.33 | 47 | 20554
2 | 4:34.05 | 4:18.47 | 20555 | 39951
3 | 8:52.52 | 6:26.15 | 39952 | 68916
4 | 15:18.67 | 5:44.28 | 68917 | 94744
5 | 21:03.20 | 5:09.20 | 94745 | 117939
6 | 26:12.40 | 5:15.35 | 117940 | 141599
7 | 31:28.00 | 4:16.40 | 141600 | 160839
8 | 35:44.40 | 7:01.47 | 160840 | 192461
Filename F:\Vinyl ; CD ; Tape Rips\# Lossless Temp\Forbidden (1988) - Forbidden Evil [WV]\Forbidden (1988) - Forbidden Evil - WV.wav
Peak level 94.2 %
Test CRC 9699877E
Copy CRC 9699877E
"CUE Sheet"
REM GENRE Metal
REM DATE 1988
REM DISCID 660A0608
PERFORMER "Forbidden"
TITLE "Forbidden Evil"
FILE "Forbidden (1988) - Forbidden Evil - WV.wv" WAVE
TITLE "Chalice Of Blood"
INDEX 00 00:00:00
INDEX 01 00:00:47
TITLE "Off The Edge"
INDEX 01 04:34:05
TITLE "Through Eyes Of Glass"
INDEX 00 08:51:52
INDEX 01 08:52:52
INDEX 00 15:17:40
INDEX 01 15:18:67
TITLE "March Into Fire"
INDEX 00 21:00:35
INDEX 01 21:03:20
TITLE "Feel No Pain"
INDEX 01 26:12:40
TITLE "As Good As Dead"
INDEX 00 31:27:00
INDEX 01 31:28:00
TITLE "Follow Me"
INDEX 00 35:43:40
INDEX 01 35:44:40
Links / Ссылки
Rapidshare
Sendspace
Megaupload
MultiUpload
MP3 320 Kbps
Death The Ultimate Reality
:true: :true: :true:
Welcome to the church of lies!!!!
Doves will die, A priest will cry, Man will tithe
Welcome to the church of lies!!!!!!!!!
Chalice of blood, Waits to fill us, Chalice of blood
:thanx: :true: :true: :true:
Да, Chalice Of Blood однозначно лучшая вещь группы :true:
metallpaparazzy
Lоcаtion: Днепропетровск
:thanx: :thanx: :thanx:
PostPosted: 08 Jan 2011
Спасибо! Хорошо звучат , заразы!!!!! 2010 тоже в кайф.
Old Time Rock`n`Roll
Lоcаtion: г.Ульяновск
Спасибо за оба альбома :thanx:
PostPosted: 09 Jan 2011
Motörheadache
Ром,спасибо за альбом ! :thanx: :true: :true:
PostPosted: 05 May 2015
будьте добры перезалейте этот первопресс.(ссылки померли) :true:
Вот здесь есть с такого же диска: http://rutracker.org/forum/viewtopic.php?t=4797314
PostPosted: 07 May 2015
Forbidden - 1988 - Forbidden Evil (1988, Combat-Relativity, 88561-8257-2, USA) [flac]
EAC extraction logfile from 16. July 2014, 15:41
Forbidden / Forbidden Evil (Combat-Relativity, 88561-8257-2, USA)
Used drive : MATSHITABD-CMB UJ160 Adapter: 0 ID: 0
Read offset correction : 103
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\FLAC\flac.exe
Additional command line options : -V -8 -T "Date=%year%" -T "Genre=%genre%" %source%
Filename D:\Ripped By liveevil\Forbidden - Forbidden Evil (Combat-Relativity, 88561-8257-2, USA).wav
Peak level 94.2 %
Extraction speed 4.0 X
Test CRC 3C894779
Copy CRC 3C894779
Track 1 cannot be verified as accurate (confidence 2) [9147AD0D], AccurateRip returned [EBADA3F4] (AR v2)
Track 2 cannot be verified as accurate (confidence 2) [DE90C8EB], AccurateRip returned [65A49857] (AR v2)
Track 3 cannot be verified as accurate (confidence 2) [BBD88A5A], AccurateRip returned [232124B7] (AR v2)
Track 4 cannot be verified as accurate (confidence 2) [EAEC068D], AccurateRip returned [6D17CAE9] (AR v2)
Track 5 cannot be verified as accurate (confidence 2) [5A026AC9], AccurateRip returned [34316D0E] (AR v2)
Track 6 cannot be verified as accurate (confidence 2) [C43FB99F], AccurateRip returned [5F3D6F63] (AR v2)
Track 7 cannot be verified as accurate (confidence 2) [3619E8F9], AccurateRip returned [20086DCD] (AR v2)
Track 8 cannot be verified as accurate (confidence 2) [0E6C591A], AccurateRip returned [A947C9C7] (AR v2)
==== Log checksum 36A5E9C46B172E792A055EF7672340793735B2922D46A672E42D2A49B8DCB5C4 ====
REM GENRE "Thrash Metal"
REM DATE 1988
REM DISCID 660A0608
TITLE "Forbidden Evil (Combat/Relativity, 88561-8257-2, USA)"
FILE "Forbidden - Forbidden Evil (Combat-Relativity, 88561-8257-2, USA).flac" WAVE
INDEX 00 00:00:00
INDEX 01 00:00:47
INDEX 01 04:34:05
INDEX 00 08:51:52
INDEX 01 08:52:52
INDEX 00 15:17:40
INDEX 01 15:18:67
INDEX 00 21:00:35
INDEX 01 21:03:20
INDEX 01 26:12:40
INDEX 00 31:27:00
INDEX 01 31:28:00
TITLE "Follow Me"
INDEX 00 35:43:40
INDEX 01 35:44:40
Как-то раньше эту группу очень уважал. Но... никогда полных альбомов не слушал. В основном или по радио (Югославия, Румыния, Польша) несколько новых (на тот момент) вещей крутили, то на дописях где-то попадались кассетных. В общем, отношение было более чем хорошее, група у меня даже в фаворитах была.
А сейчас, слушая дебютник, не понимаю, как я мог не заметить тогда такой противный вокал :(
Товарищ Расс Андерсон опрометчиво косит под Бобби Элсфорта (особенно на "Feel The Pain") и немного Чака Билли и... нелепо повизгивает при этом :yyy:
4 раза послушал альбом, в итоге - музыка и бэк-вокальные партии нравятся, а вот манера пения основного вокалиста портит весь аппетит :fingal:
Надеюсь, дальше или он или я, изменимся =)
Без оценки.
Да, и не трэш это ещё, а скорее Speed/Power :pardon:
