It is currently 25 May 2019
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: 19 Feb 2009
Lоcаtion: Таллин, Эстония.
Band / Название Группы: Deathwish
Album title / Название Альбома : Demon Preacher
Year / Год Выпуска : 1989
Genre / Жанр: Thrash Metal
Country / Страна : United Kingodom
Track list / Список Песен
01. 01:41 Death Procession
02. 05:21 Demon Preacher
03. 03:44 Carrion
04. 04:47 Visions Of Insanity
05. 04:37 Symptom Of The Universe (Black Sabbath cover)
06. 04:14 Wall Of Lies
07. 07:20 Prey To The Lord
08. 03:00 Fatal Attraction
09. 03:16 Past Life
Technical info / Технические данные .
Source / Источник : CD
Format / Формат : WV, -hh -x6. Lossless.
Resolution / Разрешение : 44 KHz / 16 Bit
Total playing time / Суммарное время проигрывания : 38:01
Album art / Полиграфия: Booklet, back cover, merchandise inlay, CD. | Буклет, задняя обложка, рекламный вкладыш, диск.
EAC Log
Exact Audio Copy V1.0 beta 2 from 29. April 2011
EAC extraction logfile from 27. November 2011, 10:26
Deathwish / Demon Preacher
Used drive  : ASUS    DRW-1814BLT   Adapter: 3  ID: 0
Defeat audio cache      : Yes
Read offset correction                      : 6
Used interface                              : Installed external ASPI interface
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.55 |  1:41.37 |        55    |     7666
        2  |  1:42.17 |  5:21.13 |      7667    |    31754
        3  |  7:03.30 |  3:43.62 |     31755    |    48541
        4  | 10:47.17 |  4:46.38 |     48542    |    70029
        5  | 15:33.55 |  4:36.40 |     70030    |    90769
        6  | 20:10.20 |  4:14.32 |     90770    |   109851
        7  | 24:24.52 |  7:20.10 |    109852    |   142861
        8  | 31:44.62 |  3:00.25 |    142862    |   156386
        9  | 34:45.12 |  3:16.25 |    156387    |   171111
     Filename F:\Vinyl ; CD ; Tape Rips\# Lossless Temp\Deathwish (1989) - Demon Preacher [WV]\Deathwish (1989) - Demon Preacher - WV.wav
     Peak level 91.7 %
     Extraction speed 6.6 X
     Range quality 99.9 %
     Test CRC BA49E530
     Copy CRC BA49E530
Track  1  not present in database
Track  2  not present in database
Track  3  not present in database
Track  4  not present in database
Track  5  not present in database
Track  6  not present in database
Track  7  not present in database
Track  8  not present in database
Track  9  not present in database
CUE Sheet
REM GENRE "Thrash Metal"
REM DATE 1989
REM DISCID 6E08E909
REM COMMENT "ExactAudioCopy v1.0b2"
PERFORMER "Deathwish"
TITLE "Demon Preacher"
FILE "Deathwish (1989) - Demon Preacher - WV.wv" WAVE
    TITLE "Death Procession"
    INDEX 00 00:00:00
    INDEX 01 00:00:55
    INDEX 01 01:42:17
    TITLE "Carrion"
    INDEX 01 07:03:30
    TITLE "Visions Of Insanity"
    INDEX 01 10:47:17
    TITLE "Symptom Of The Universe"
    INDEX 01 15:33:55
    TITLE "Wall Of Lies"
    INDEX 01 20:10:20
    TITLE "Prey To The Lord"
    INDEX 01 24:24:52
    TITLE "Fatal Attraction"
    INDEX 01 31:44:62
    TITLE "Past Life"
    INDEX 01 34:45:12
Comment / Комментарий
Второй альбом этой Британской Трэш Метал команды. Влияние Хеви Метала довольно сильное. Звучание уникальное. Попутно я вписал КУЙ в сам аудио файл. Пользователи foobar2000 могут вместо КУЯ открыть сам файл.
This is the second album by these British thrashers. The Heavy Metal influence is quite strong. The overall sound is unique. The audio file features an inbuilt CUE Sheet. Those of you using foobar2000, may open the audio files itself, instead of a CUE sheet.
Links / Ссылки
Megaupload - Lossless
Rapidshare - Lossless
MultiUp - Lossless
Narod - Lossless
Megaupload - MP3 320
Death The Ultimate Reality
Спасибо, Рома :true:
От меня тоже мерси! :thanx:
И от меня! :thanx: :true:
вот за это дичайшее и мега-дьявольское спасибо!!!!!!!!!
Слушайте / Кушайте наздоровье :smile:
PostPosted: 21 Feb 2009
Lоcаtion: Донбасс
Большое спасибо! :thanx:
PostPosted: 27 Feb 2009
Если не сложно, то сделайте, плиз, зеркала=) На что-нибудь, типа мегааплоад, ипака, аксильфайлз итп
PostPosted: 28 Feb 2009
Ок... Скоро.
PostPosted: 17 Sep 2009
Обложки может кто-нибудь отдельно залить?А то качал альбом в другом месте без облог...
PostPosted: 18 Sep 2009
Lоcаtion: Пенза
Сканы с диска Романа..
http://rapidshare.com/files/281620927/__scans.rar
PostPosted: 19 Sep 2009
Спасибо! :true:
PostPosted: 19 Mar 2010
Спасибо! :true:
PostPosted: 25 Nov 2011
Перезалейте, пожалуйста, на мегу или ипапку.
PostPosted: 27 Nov 2011
Ой. Аж 4 варианта этого альбома на винте у себя нашёл :oops:
Завтра ливану аповский.
Ой-2. Пардон, а этого как раз сейчас и не вижу... :fingal:
Могу и сам перелить. Только уже не АПЕ, а в ВАВПаке.
Перериповал, перелил, переформил. Осталось ещё пару зеркал сделать для полного счастья.
Рома, спасибо :thanx: , щас отзекалю :true:
Ой! Четыре варианта одного и того же релиза??? Зачем столько? :-))
Спасибо огромное!
