It is currently 05 Jul 2026
PostPosted: 19 Sep 2016
Asgard 2011 - The Seal Of Madness
Genre : Heavy/Speed Metal
Country : Italy
Label : My Graveyard Productions
Site : http://www.metal-archives.com/bands/Asgard/80832
Tracks : 9
Playtime : 00:37:31
Size : 318 MB / 86.70 MB
Codec : FLAC (img+cue+log+scans)/lossless & MPEG 1 Layer III/320 kbps
Tracklist :
01. Disciples (03:28)
02. I Spit On Your Hands (03:14)
03. The Seal Of Madness (04:21)
04. With Your Shield Or On It (04:12)
05. Army Of Darkness (05:35)
06. Fury Of The Night (02:24)
07. The Age Of Steel (05:30)
08. Hellbreaker (04:48)
09. Asgard Invasion (03:56)
EAC log | +
EAC extraction logfile from 1. July 2011, 21:30
Asgard / The Seal Of Madness
Used drive  : ASUS    DRW-22B2S   Adapter: 0  ID: 1
Defeat audio cache      : Yes
Read offset correction                      : 6
Used interface                              : Native Win32 interface for Win NT & 2000
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.00 |  3:28.42 |         0    |    15641
        2  |  3:28.42 |  3:14.22 |     15642    |    30213
        3  |  6:42.64 |  4:20.73 |     30214    |    49786
        4  | 11:03.62 |  4:12.10 |     49787    |    68696
        5  | 15:15.72 |  5:35.32 |     68697    |    93853
        6  | 20:51.29 |  2:23.74 |     93854    |   104652
        7  | 23:15.28 |  5:30.63 |    104653    |   129465
        8  | 28:46.16 |  4:48.17 |    129466    |   151082
        9  | 33:34.33 |  3:56.24 |    151083    |   168806
     Filename C:\Asgard - 2011 - The Seal Of Madness.wav
     Range quality 99.9 %
     Test CRC 94F1BF30
     Copy CRC 94F1BF30
Track  1  not present in database
Track  2  not present in database
Track  3  not present in database
Track  4  not present in database
Track  5  not present in database
Track  6  not present in database
Track  7  not present in database
Track  8  not present in database
Track  9  not present in database
Lossless
Mp3
Asgard 2013 - Outworld
Country : Italy
Tracks : 9
Playtime : 00:41:00
Size : 331 MB / 94.53 MB
Tracklist :
01. Spirits (04:32)
02. The Interceptor (04:05)
03. Sound Of Shadows (06:03)
04. Outworld (04:39)
05. Wall Of Lies (04:26)
06. Riot Angels (04:10)
07. The Night Hawk (04:26)
08. Cyber Control (02:55)
09. Marry The Widow (05:40)
EAC log | +
Отчёт EAC об извлечении, выполненном 9. сентября 2016, 18:14
Asgard / Outworld
Дисковод: TSSTcorpCDDVDW SE-208DB   Adapter: 1  ID: 0
Режим чтения                 : Достоверность
Отключение кэша аудио        : Да
Использование указателей C2  : Нет
Коррекция смещения при чтении                     : 6
Способность читать области Lead-in и Lead-out     : Нет
Заполнение пропущенных сэмплов тишиной            : Да
Удаление блоков с тишиной в начале и конце        : Нет
Интерфейс                                         : Встроенный Win32-интерфейс для Win NT/2000
Выходной формат          : Пользовательский кодировщик
Выбранный битрейт        : 1024 kBit/s
Качество                 : Высокий
Добавление ID3-тега      : Да
Утилита сжатия           : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Дополнительные параметры : -V -8 -T "Date=%year%" -T "Genre=%genre%" %source%
TOC извлечённого CD
     Трек |   Старт  | Длительность | Начальный сектор | Конечный сектор
       1  |  0:00.00 |    4:31.74   |           0      |      20398
       2  |  4:31.74 |    4:04.70   |       20399      |      38768
       3  |  8:36.69 |    6:03.69   |       38769      |      66062
       4  | 14:40.63 |    4:39.56   |       66063      |      87043
       5  | 19:20.44 |    4:26.44   |       87044      |     107037
       6  | 23:47.13 |    4:10.40   |      107038      |     125827
       7  | 27:57.53 |    4:25.72   |      125828      |     145774
       8  | 32:23.50 |    2:55.68   |      145775      |     158967
       9  | 35:19.43 |    5:40.48   |      158968      |     184515
Выбранный диапазон
     Имя файла E:\Rutracker\DissidentAggressor\Asgard\Outworld\Asgard - Outworld.wav
     Пиковый уровень 100.0 %
     Скорость извлечения 7.0 X
     Качество диапазона 100.0 %
     CRC теста 3AA94810
     CRC копии 3AA94810
     Копирование... OK
Ошибок не произошло
AccurateRip: сводка
Трек  1  : извлечено точно (доверие 2)  [3A105BC4]  (AR v2)
Трек  2  : извлечено точно (доверие 2)  [2B9B84EC]  (AR v2)
Трек  3  : извлечено точно (доверие 2)  [991CBE85]  (AR v2)
Трек  4  : извлечено точно (доверие 2)  [2AA10078]  (AR v2)
Трек  5  : извлечено точно (доверие 2)  [958B58E3]  (AR v2)
Трек  6  : извлечено точно (доверие 2)  [DA08FBB9]  (AR v2)
Трек  7  : извлечено точно (доверие 2)  [20CECF34]  (AR v2)
Трек  8  : извлечено точно (доверие 2)  [9127EEE7]  (AR v2)
Трек  9  : извлечено точно (доверие 2)  [A6699E16]  (AR v2)
Все треки извлечены точно
Конец отчёта
==== Контрольная сумма отчёта 43E53A1F98654154E701D1F868B5374CAE2EEB291E685BEBB0232AC5335EA038 ====
Lossless
Mp3
олдскульненько так...
Добротная бандочка.Мне по душе!
Спасибо!
надо будет на мордокниге у них за демки спросить... :scratch:
2004 - The Return of the King
01. Hail and Kill (Manowar cover)
02. The Trooper (Iron Maiden cover)
03. The Return of the King
04. Guardians of the holy Gates
2006 - Asgard
01. Fury of the Night
02. Keep the Flame Alive
03. Disciples
04. Guardians of the Holy Gates
PostPosted: 20 Sep 2016
mirror:
2011 - iFolder l Narod l M-Cloud
2013 - iFolder l Narod l M-Cloud
Нравится альбом.
Помесь хэлловинщины приличной и вокала в духе Sacred Steel, только намного приятного и втемного :meloman:
6+/10
Толику очень рекомендуется :dance: А Егор и сам знает эту группу :lob:
Да слушал один трек когда-то))
А вообще этих Асгардов дофига и больше. Немецких и то целых три :scratch:
PostPosted: 21 Sep 2016
а лучший все равно голландский
Отлична команда, давно уже слушаю, нравится больше и больше! Не нудно, истерично, драйвово. :pardon:
пообщался с гитаристом Dave Penoncini... у них демок нетути :vic:
Тоже хороши на этом альбоме и ещё более :meloman: :lob: :lob: :lob:
7/10
И всё же и это Хэлловинщина. В основном из-за фальцетного вокала и его манеры петь.
Полез было на М-А добавлять симилярных группы, но меня трохи... отторгнули :arrow: http://www.metal-archives.com/band/ajax ... s/id/80832 :pardon:
А чего ответил? Просто - "демок нет!!" ? :fingal:
Ну не могёт такого быть, чтобы не было. Явно на компах старых валяются.
как-то так
Hi, and thank you for your greeting, Vladimir!
Actually, our first demo (2006) is not available, and I didn't find any of his song on youtube; for the second one, I found this https://www.youtube.com/watch?v=xo9zqAcyeaA and this https://www.youtube.com/watch?v=LVzT1cmu8KU
Anyway except for the first demo ever, songs were re-recorded, and you can find them in the official releases!
thanks again!
Thanks, Dave ! I'm just basically interested of cover version manowar and iron maiden - I collect all sorts of covers )
I'm pretty sure we didn't published yet. If you're lucky, maybe some fan put some live version on you tube.
Anyway, that covers was very amateaurly played and recorded
I mean...
Второй альбом, 7-я песня. Есть восточный мотивчег? :scratch:
Asgard - 2013 - The Night Hawk
На Ютубе только заловый вариант нашёл... https://www.youtube.com/watch?v=ediMyoIFySo
I mean...
Ага, ну, явно либо у них в контракте пункт указана про неиздание каверов официально, либо.. Да просто зажали :pardon:
