It is currently 12 Jul 2026
PostPosted: 05 Jan 2010
Technical Crime Full-length, 1998
Sweatshops Full-length, 2002
Das Kapital Full-length, 2004
As God Kills Full-length, 2006
PASQ
:fingal: viewforum.php?f=3 :fingal:
Wrong Request, Read the Rules!
You're Giving First Warning
PostPosted: 06 Jan 2010
what have you done Scatterbrain :shok:
I don't understand russian sorry!
Can you put off the warning??
anyway found.......
http://melodicdeathmetal.blogspot.com/2007/03/node.html
Node - Sterilized
EP, Lucretia Records
December 2000
[add/edit review]
[Average rating for 1 review is 35%]
Released in December 2000
contains some old tracks
and two unreleased tracks
Produced by Livio Magnini & Node
Line-up:
Daniel Botti - vocals and guitars
Steve Minelli - guitars
Klaus Mariani - bass
Oinos - drums
1. Sterilized
2. Virtual God
3. New xxx
4. Ask (1997 Version)
5. Tronic Prophecy
6. Unaffected
:shok: viewforum.php?f=3
Correctly issued inquiry should be as muсh as possible clear and look like as follows: We write a group name In the topic name, style and its location: an example: [reqs] Slayer - [US, California] - Thrash Metal – a prefix presence in the name of the theme is obligatory.
It is necessary to list the following things: which album and track-list we are searching for, what quality will suit (probably you are looking for an original record or the Japanese, American/Russian reedition?), we insert the picture (to 300х300 px), we copy track-list (the edition you are searching for!). It will be useful if you point out some information about the group and quality of a required product (a size, bitrate). Before the inquiry have a forum search.php
Each topic requires separate search. If you see required group in "Announcements" and want to have its other albums, it is necessary to make a request in created theme. It will be transferred by moderators to "Requests", and in a process of request performance the name prefix [reqs] will be cleaned.
If the information above is unclear for you, have a look at the following example viewtopic.php?t=2707
Messages are placed in an alphabetic order and only in forum subsections only Запросы / Requests (mp3)
I'm italian...
I too understand only Russian, therefore it is necessary to communicate with foreigners with the help of electronic translators Google translate or others, for example I use PROMT. :oops:
Capisco anche solo la lingua russa, quindi dobbiamo comunicare con gli stranieri utilizzando i traduttori elettronici Google Translate, o altri, per esempio, io uso PROMT :umnik:
PostPosted: 07 Jan 2010
Node - Sterilized
